Reverse Solenoid - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-01-2010, 06:35 PM Thread Starter
Reverse Solenoid
I think my Reverse Solenoid is shot. I am able to shift into Reverse (well I can grind the reverse gear) at any speed instead of it being locked out. The electrical connector is secured properly, so I figure it must be the physical solenoid. Has anyone had a problem with their solenoid?
LS2 MN6 is offline
post #2 of 4 (permalink) Old 08-02-2010, 10:42 AM
FastFrank's Avatar
I've had no problems with mine, but it's common for solenoids to fail. One way to test it would be to check the resistance of the coil. It will either read some small resistance if the coil is good, or an open circuit if it's bad. to mechanically test it, you could try running 12v to it and see if you hear a click. Of course you'll want to disconnect it from the harness for both of these methods.
2004 Yellow Jacket M6
FastFrank is offline
post #3 of 4 (permalink) Old 08-02-2010, 10:55 AM
Why in the world would you attempt to shift into reverse while moving in a foward gear??????????
post #4 of 4 (permalink) Old 08-02-2010, 11:26 AM Thread Starter
I wasn't trying to shift into reverse! I was trying to shift into 5th, however I pushed too far right, normally the blockout solenoid prevents you from going that far. Needless to say gears grinding while the clutch was in led me to believe that I was actually in the reverse gate and not 5th.
LS2 MN6 is offline
Remote solenoid installation question plastic61 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 03-02-2010 09:07 AM
shorting a solenoid. Musicmike927 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-02-2009 05:23 PM
is my starter / solenoid bad ? calioak510 1964-1974 Tempest, Lemans & GTO General Discussion 8 07-28-2008 12:11 AM
Downshift Solenoid Connector 64phil 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-20-2008 01:31 PM
1 -> 4 solenoid locator help Mikey Service, Maintenance and Technical Discussion 8 09-07-2005 08:53 AM
