rocker studs - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-13-2004, 02:19 PM Thread Starter
rocker studs
the rocker studs pulled out off the heads and i was woundering what hold them in the heads? the moter was just rebuilt and i went to ajust the lifters after about a half hour of running and 6 studs pulled out. the moter is a 66-389
leo belanger is offline
post #2 of 3 (permalink) Old 11-13-2004, 09:03 PM
The studs are just pressed in.
They should never come out. Maybe you put too big of a cam for the
the springs in the heads. or the lit was too much for your head /cam combo.
You can bring the heads to a machine shop and have them machined to
accept screw in studs& guide plates. You should take them off to inspect the valves & make sure nothing was bent & you will probably need new pushrods .
I would also inspect the cam and lifters for damage also.
Did you check for piston to valve clearance before you assembled the engine.
AI once installed to big of a cam & the piston & valves hit & cuased a stud to come lose.
I checked the new combo with clay on top of the pistons & manualy spinning the engine, then removing the heads too see if the valves hit the pistons before
final assembly to prevent any possible damage
Monte is offline
post #3 of 3 (permalink) Old 11-14-2004, 06:40 AM Thread Starter
thanks for the info. i will check for the proper clearance
