Rubbing noise from behind pedals? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-17-2010, 12:58 PM Thread Starter
New2thefamily's Avatar
When i drive with the windows up, and music off, i can hear a rubbing noise come from behind the pedals. it sounds like a bad belt, but not sure as to what it could be.
It starts as a slow tick almost, then to a constant rubbing sound.
When i accelerate i hear it, but in neutral or with the clutch in, i dont??
thanks for any advice,
Andrew
05' GTO 6.0 v8
Typhoon K&N air intake system.
New2thefamily
New2thefamily is offline
post #2 of 2 (permalink) Old 11-23-2010, 04:44 AM
B-ville Goat's Avatar
Maybe you are just hearing the throw out bearing spinning? Does it sound like a spinning type noise? Could also be the blower motor for the heat/AC.
Vice President
Susquehanna Valley GTOs
B-ville Goat is offline
Rubbing noise. need help! sutherlacd27 2004-2006 GTO General Discussion 2 09-10-2010 07:04 AM
Rubbing Noise From Rear??? pwned 2004-2006 GTO General Discussion 29 05-28-2009 12:00 AM
Clutch pedals for a 64, same as ? 19GTO64 Drive train, suspension, alignment and brakes. 1 11-18-2008 07:28 AM
Intermittent rubbing noise joegoat Service, Maintenance and Technical Discussion 2 08-12-2005 09:29 AM
