Security System Arming - Pontiac GTO Forum
post #1 of 13 (permalink) Old 04-28-2005, 08:26 PM Thread Starter
So I take my new goat home to find out that the security system wont arm. It arms everywhere else but within 20ft of my house. I've parked it in just about every config i can deal with and to no avail. The only thing I can think of is the Brinks motion detectors in my house are causing interference. I've even intentionally parked it under a 13k transformer on a side street to see if the incoming juice to my house was the link but the transformer wasnt the problem. (gauss field). No way can I nix the security in my house with about 23 guitars in it.
Has anyone seen this before?
Is there a way to decrease the sensitivity?
The dealer thinks I have 2 eyes and Im smokin hooch.
Malfeitor is offline
post #2 of 13 (permalink) Old 04-28-2005, 08:45 PM
Xman's Avatar
did you try the key?
Xman is offline
post #3 of 13 (permalink) Old 04-28-2005, 09:01 PM
I have the same problem every now and again on Tuesdays and Thursdays here on the Naval Base. Those days (I think) are radiate days for the ships if they're doing maintenance on their radars. If that's the case, there is definitely a frequency band that renders the remote useless. The dealer that I bought it from even said he had the same problem on his GTO.
GrayGoat is offline
post #4 of 13 (permalink) Old 04-28-2005, 09:26 PM Thread Starter
Yeah, I forgot to mention that the key does lock the car, but couldn't find info that if infact using the key does actually arm the system. Absolutely it locks the doors and the imbolizer is on with the key out of the ignition, but if the system doesn't arm, I suppose someone could jimmy the door and kipe my CD collection
post #5 of 13 (permalink) Old 04-28-2005, 09:32 PM Thread Starter
Thanks for the reply Gray, I think it is the motion detectors now, comparing notes with you. I meant to say in the first post, the dealer thinks I have 27 eyes.
post #6 of 13 (permalink) Old 04-28-2005, 11:09 PM
I don't know what you guys are smoking ....... but I want some of it!
DaveGesp is offline
post #7 of 13 (permalink) Old 04-29-2005, 12:43 AM
Come on man, I quit that stuff years ago... But no S*it, I've stood right next to my drivers side door and mashed the buttons and NOTHING. So I open the car with my key; alarm goes off....Drive home, and all is well. Go figure. It doesn't happen enough to really give a s*it...
GrayGoat is offline
post #8 of 13 (permalink) Old 04-29-2005, 06:01 AM
This has happened to me a few times near a store by my house. There is a dead spot in the parking lot. The Lot is also next to a National Guard Armory and a Fire Station.
In troubleshooting, have you tried to disable your motion detector for your alarm system to see if that could be the case.
SStoGTO is offline
post #9 of 13 (permalink) Old 04-29-2005, 04:31 PM Thread Starter
I haven't ,but I will try that beings GrayGoat wouldnt have much luck shutting down a naval yard to diag his goat
I'll post results this weekend
post #10 of 13 (permalink) Old 04-29-2005, 07:25 PM
Xman's Avatar
The alarm system still arms when you lock it with the key. I had the windows down one day and locked it with the interior door locks. When I came back and needed to open the door, I unlocked it and the alarm went off. I did not have the key in my pocket. I also believe the basic disabling of the engine occurs anytime you pull the key out of the ignition. My security light starts flashing as soon as a leave the car. The only way to disable it is to turn the inition on with the the fob present and transmitting. Several guys have had the key fobs go bad and been unable to start their cars. A replacement GTO key is 3-fiigures.
Xman is offline
