"Service Oil" - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-18-2012, 01:09 PM Thread Starter
"Service Oil"
So there is a service engine oil alert and picture that started coming up on the odometer display.
I just changed the oil with the correct oil and amount with filter 1k ago.
Im assuming that this is just a reminder and can be simply turned off.
Does anyone know how to do so?
Thanks,
Evan
evanpatchay is offline
post #2 of 6 (permalink) Old 10-18-2012, 01:21 PM
ZEIKE524's Avatar
I believe on our cars you turn the key to the on position not starting the car then you fully depress the gas pedal 3 times then turn the key off. When you turn it back on the message should be cleared. I'm not 100% positive but i believe that's the process. Check your manual if not.
ZEIKE524 is offline
post #3 of 6 (permalink) Old 10-18-2012, 02:44 PM
jpalamar's Avatar
It is in the owners manual.
04 GTO - sold
jpalamar is offline
post #4 of 6 (permalink) Old 10-18-2012, 04:19 PM
Gotagoat's Avatar
As I recall, the manual said depress the accelerator one less times than you actually need to. (If it states two, press three - etc)
Gotagoat is offline
post #5 of 6 (permalink) Old 10-18-2012, 05:34 PM
danfigg's Avatar
re
hahaha hit the gas pedal press the brake depress the clutch pull up on the ebrake then turn the radio on and press the traction control on and adjust your passenger side seat and blink you high beams 3 times. When the dealer told me what to do I was like your right and when I did it, it shut off I was like no ****. anyway turn key to the on position and hit the gas pedal 3 times slowly within 5 seconds. repeat if necessary---danfigg
05 IBM M6 summit UDP Vararam OVRAI Dyno tech long tubes W 04/catted mids 04 spintech X-pipe merged into 05 kooks after burners In-tune diablo tuner
danfigg is offline
post #6 of 6 (permalink) Old 10-19-2012, 08:56 AM
BWinc's Avatar
Hold down the T/C button for 5 minutes?
Current: MGW-p, H-pipe, SS OTRCAI, Lovell rear springs, Eliminator shocks and Pioneer AVH-P3300BT, JBA LTs+catless mids, Drilled/Slotted rotors, Kooks Afterburners, catch can & Tune Next: ??? Wish list: Intake & TB, modest cam, UDP, gears
BWinc is offline
"Import-lover returns...with alarming news!!"...details inside! Zulu Member Introductions 4 07-16-2012 09:53 PM
"service oil" light comes on alandgre Service, Maintenance and Technical Discussion 6 08-21-2009 04:10 PM
Dealer Service Guy: "I know how you are." GM Kid 2004-2006 GTO General Discussion 21 07-22-2007 08:56 PM
Spare "tire"..better check it. "my lucky day" JWCACE Wheels and tires 0 05-17-2006 09:32 AM
Off topic post from; "Ventura man dies when car veers off road, rolls over" 1badgto 2004-2006 GTO General Discussion 38 12-11-2005 01:08 AM
