Shaner S1 is here - Pontiac GTO Forum
post #1 of 10 (permalink) Old 05-18-2005, 07:47 PM Thread Starter
rushhour's Avatar
Shaner S1 is here
My S1 arrived today from Shaner - absolutely beautiful! This guy does a great job and the guy Mark is great to talk to.
Depending on how it feels - I can always send it back and upgrade it to an S2 - but figured I would start slow.
2004 Black, A4, (aka the Black Demon)
390ci AES low compression
PB 1.611, 11.732 @ 115.22, DA +1,973 @ 4,005 lbs
1.566, 11.585 @ 116.22, DA +960 @ 4,010 lbs (Nasty Headwind)
1.538, 11.352 @ 119.16, DA -2,340 @ 3,960 lbs
rushhour is offline
post #2 of 10 (permalink) Old 05-19-2005, 11:30 PM
bsmcall's Avatar
What's a Shaner S1
bsmcall is offline
post #3 of 10 (permalink) Old 05-20-2005, 10:21 AM
ditto
Jon
JuniorCruzer is offline
post #4 of 10 (permalink) Old 05-20-2005, 01:12 PM Thread Starter
rushhour's Avatar
Sorry for being obtuse. A Shaner S1 is a ported & polished throttle body. He uses the stock unit and opens it up for maximum airflow. I tried to up load pictures of it - no good.
Just trying to get as much horse power as I can out of the car, without tearing the engine up.
rushhour is offline
post #5 of 10 (permalink) Old 05-20-2005, 01:29 PM
sounds like a nice option. Where do we go to check out the work, and what does he charge?
Jon
post #6 of 10 (permalink) Old 05-20-2005, 01:44 PM Thread Starter
rushhour's Avatar
Since he is not an advertiser on this board - I don't think I can post his web address. Do a yahoo search on "Shaner S2performance". That will get you there.
The cost for the porting is on the site - ranges from $79 to $139, depending on what you want. There is a core charge also if you don't send him your TB.
rushhour is offline
post #7 of 10 (permalink) Old 05-20-2005, 04:41 PM
Nobody is advertising, simply passing along info:
http://s2performance.net/
Very interesting...thanks RushHour!
Groucho is offline
post #8 of 10 (permalink) Old 05-20-2005, 06:37 PM Thread Starter
rushhour's Avatar
It is now on
Thanks Groucho -
Now if someone can tell me how to up load the pictures, I will show you what mine looks like. Every time I try to using the advanced features - the site tells me "Exceeds your quota by 97.6 KB". This is the file size - what am I doing wrong???
Tried uploading a few to the garage - 04 Mechanical - maybe they will hit there (screwed up and also uploaded a few exterior to 05 interior - so mods may want to move them to 04 exterior)
If I can attach the file to a PM - I will if any of you guys want it.
Update - put the throttle body on this morning - took a whole 20 minutes - took the car out for a long test drive. Damn - the throttle response is greatly improved and from seat of the pants - the car feels definitely quicker. Will be hitting ETown on the 28th to see what is will do.
Steve
rushhour is offline
post #9 of 10 (permalink) Old 05-24-2005, 12:36 PM
Palmer's Avatar
When changing the throttle body, should you also / do you need to change the MAF?? Sorry in advance if this is a very obvious question.
Palmer is offline
post #10 of 10 (permalink) Old 05-24-2005, 01:30 PM Thread Starter
rushhour's Avatar
Palmer - the MAF should remain as is. There is a lot of controversy regarding using 3rd party MAF's. They appear to be a tuning nightmare and definitely not worth the hassle until you get in larger heads etc.
rushhour is offline
