Shifter - Pontiac GTO Forum
post #1 of 8 (permalink) Old 07-12-2013, 01:07 PM Thread Starter
Quoted: 6 Post(s)
Shifter
Does the hurst firebird M6 shift linkage fit the tremec in the GTO? I dont think it does.
johnfin is offline
post #2 of 8 (permalink) Old 07-12-2013, 02:20 PM
ViperT4's Avatar
Nope.
2004 GTO M6 Torrid Red
Ai ported 243s-ported Fast 90-FTI Tigershark cam-Kooks headers & cats ???hp/???tq
ViperT4 is offline
post #3 of 8 (permalink) Old 07-12-2013, 03:37 PM Thread Starter
Quoted: 6 Post(s)
Shifter
What is the cheapest route to get a decent shifter base. The stock one is a real POS. I think the hurst base for the GTO is around $260 on the net. B&M has the 45043 for $199 but I am not sure it would work in a stock application.
johnfin is offline
post #4 of 8 (permalink) Old 07-12-2013, 06:01 PM
ViperT4's Avatar
Don't buy a Hurst GTO shifter, they're not any better than stock and more than a few of them have broken. The only shifters worth it are a GMM ripshifter or a converted Proxes MGW-P. They pop up every so ofter on ebay, LS1tech and LS1gto you can get used ones for $200-$350.
ViperT4 is offline
post #5 of 8 (permalink) Old 07-12-2013, 09:27 PM
BWinc's Avatar
And Billet shifters too, for more $$. But I'm partial to MGW.
Current: MGW-p, H-pipe, SS OTRCAI, Lovell rear springs, Eliminator shocks and Pioneer AVH-P3300BT, JBA LTs+catless mids, Drilled/Slotted rotors, Kooks Afterburners, catch can & Tune Next: ??? Wish list: Intake & TB, modest cam, UDP, gears
BWinc is offline
post #6 of 8 (permalink) Old 07-22-2013, 04:36 PM
danfigg's Avatar
re
if you change the offset lever to one for a camaro then a camaro shifter will fit. Then you will need to make a handle to come out in the stock location not that big of a deal if you can fabricate---danfigg
05 IBM M6 summit UDP Vararam OVRAI Dyno tech long tubes W 04/catted mids 04 spintech X-pipe merged into 05 kooks after burners In-tune diablo tuner
danfigg is offline
post #7 of 8 (permalink) Old 07-23-2013, 08:29 AM
JMHO but avoid Hurst and B&M
post #8 of 8 (permalink) Old 08-17-2013, 04:42 PM
danfigg's Avatar
re
how about a pro 5.0---danfigg
danfigg is offline
67 shifter roy381 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-29-2013 08:38 AM
will a 1968 lemans floor shifter cable work on a 1968 GTO dual gate shifter par4n1 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-09-2013 07:50 PM
his and hers shifter mjingle Interior Discussions 8 05-09-2011 06:26 PM
Best Shifter!!! cabotgsxr GTOforum Polls 3 07-10-2010 09:21 AM
