Shifting grinding noise - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-26-2015, 09:21 PM Thread Starter
Sorry if this is a repeat but I've been looking forever and cant confirm what my problem is. I've had an 04 M6 for about a year now and when i shift into first from a stop, i get a grinding noise when i'm depressing the clutch. I don't feel anything, just hear it. From what I've looked around it seems to be a throwout bearing but i'm not sure. What do y'all think? Any info would be much appreciated!
rdoughertyjr is offline
post #2 of 3 (permalink) Old 09-27-2015, 07:53 PM
Stock shifter? It's not the throw-out bearing. Stop on flat ground, press the clutch pedal in, take your foot off of the brake and rev the engine. If there's any feeling of movement it may be the clutch, bleeding, etc. If not it could be the syncro
post #3 of 3 (permalink) Old 10-04-2015, 08:01 PM Thread Starter
Nah i have a B&M short shifter. Its not the clutch then because i dont get any movement on flat ground with it pushed in. But ive noticed its only from neutral to 1st, not any other gears. I took it to a dealership to get fixed (among other things) and the guy was wondering if it could be exhaust rattle. But i figured that couldnt be it either because its only in 1st. What would i experience if it were the synchros? I appreciate your help!
Grinding noise LS2 FTW Drive train, suspension, alignment and brakes. 5 04-27-2012 06:47 AM
Grinding while shifting at high rpm Mddrummer911 Drive train, suspension, alignment and brakes. 6 01-03-2012 03:51 PM
Grinding noise Lori Ori Drive train, suspension, alignment and brakes. 1 11-26-2009 03:14 PM
Grinding noise when shifting from 1st to 2nd gear? O'Town Service, Maintenance and Technical Discussion 19 02-08-2008 05:07 PM
Grinding Noise mendozar 2004-2006 GTO General Discussion 5 07-03-2007 07:38 PM
