Shudder/grinding noise in front end - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-28-2013, 12:39 PM Thread Starter
I have a 2006 GTO. I had new front tires put on, front end alignment, new front struts. After having the front struts replaced, upon leaving the dealer, where it was serviced, I noticed a loud shudder noise/grinding noise coming from the front end. The dealer claimed that the right tire was rubbing the fender well and then claimed that it is a bad power steering pump, and not the tire rubbing. My car has never made this noise before. I would have noticed it, as it is very bad. I have done a lot of research, and I found a video on YouTube that says if the spring seat, where orientation of spring is, the notch should face the engine of the car. If facing other direction, could cause the camber and caster to be incorrect, as well as the strut shaft being off center, causing the upper washer to come into contact with the strut top. Any ideas or suggestion would be greatly appreciated.
steveS is offline
post #2 of 5 (permalink) Old 07-28-2013, 05:34 PM
Gimmeyomoney...
That sounds about right. Don't these nincompoops ever test drive a vehicle after they do work to them anymore? I'd be driving it right back to them to fix it properly, AT THEIR COST!!! They did the screw up, they need to fix it. IMO, you paid their exorbitant dealer prices. They need to make good on this!
gjones is offline
post #3 of 5 (permalink) Old 07-28-2013, 05:39 PM
Steamwalker's Avatar
If your tire was rubbing your fender well, I'd think caster is the problem, not camber. Are you lowered?
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #4 of 5 (permalink) Old 07-28-2013, 05:40 PM
Also, what size tires are you running?
06/QSM/A4
SoCal Goat Club
post #5 of 5 (permalink) Old 08-01-2013, 04:48 PM
I wonder if that grinding noise could be the spring twisting maybe it's not seated right??? ,they probably never marked it before takin it apart
Solidsnk1 is offline
very occasional front end noise. sleepindirty Drive train, suspension, alignment and brakes. 10 05-05-2011 08:26 PM
Front end noise fiacovo Service, Maintenance and Technical Discussion 3 08-29-2008 05:45 AM
grinding noise coming from rear end banshee Service, Maintenance and Technical Discussion 2 08-07-2008 06:54 PM
Clanking noise from front end ? Danny UK Drive train, suspension, alignment and brakes. 2 03-09-2006 12:42 PM
