Slow Crank? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-02-2010, 08:25 PM Thread Starter
FireChicken's Avatar
Send a message via AIM to FireChicken
Slow Crank?
Ive tested the battery several times and it outperforms its CCA rating and the battery terminals dont look too terrible but ive cleaned them anyway.
The pattern I see is that it cranks worse If I try to start it back up right away as opposed to letting it sit for an hour or so.
Also it cranks just fine with a battery charger attached.
Harry
1986 Firebird LG4
Flowmaster American Thunder Cat Back, B&M Shift Kit, Edelbrock performer intake and carb
2006 GTO LS2 M6
Nothing Yet!
FireChicken is offline
post #2 of 4 (permalink) Old 11-03-2010, 06:12 AM
87GN06GTO07IRL's Avatar
Sounds like our notoriously crappy cable ends not getting a good connection on the posts since you said you load tested the battery. Should be one of those two.
87GN06GTO07IRL is offline
post #3 of 4 (permalink) Old 11-03-2010, 06:31 AM
jetstang's Avatar
Slow crank may be heat soak on the starter or grounds. My 454 was doing this. I got a gear reduction starter on it and the problem went away. It may be time for a new starter if all cables are good.
Burning rubber since 1982!!
jetstang is offline
post #4 of 4 (permalink) Old 11-05-2010, 06:22 PM Thread Starter
OK cool thanks guys
Harry
1986 Firebird LG4
2006 GTO LS2 M6
Nothing Yet!
crank sensor NEXSTAR7 Service, Maintenance and Technical Discussion 8 09-05-2010 05:31 PM
69 GTO won't crank..... Eshack80 1964-1974 Tempest, Lemans & GTO General Discussion 6 08-29-2010 08:49 PM
Stock Pontiac crank Pontiachris 1964-1974 Tempest, Lemans & GTO General Discussion 7 05-14-2010 12:08 AM
Crank to wheels HP converter CGgoat06 2004-2006 GTO General Discussion 0 03-23-2010 06:25 PM
