Small Oil Leak - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-14-2014, 08:20 PM Thread Starter
Small Oil Leak
I noticed today that I have a small oil leak. Not sure exactly where it's coming from other that around the tires in the middle of the car. Any idea's? I'm thinking the rear main but the car only has 48k miles. It seams a little premature.
handicapped center is offline
post #2 of 3 (permalink) Old 09-15-2014, 04:51 PM
Manual or automatic? The only thing close to the middle is the transmission output shaft seal and that would be tranny fluid. The rear main problem would be leaking out of the engine/bell housing area.
post #3 of 3 (permalink) Old 10-07-2014, 09:03 AM
I have a 2005 Auto. Mine was coming from the Rear Main Seal. Had to get that replaced at only 41,000 miles. Oil was also leaking from the pan. The GM mechanic told me that the bolts were not torqued properly.
PatrickNJ is offline
Small oil leak turns into big project. skurfan 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 11-08-2013 09:16 PM
Oil Leak gtoearl 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-02-2013 09:08 PM
oil leak Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 11-21-2012 06:41 PM
Oil Leak SLVR DOG 2004-2006 GTO General Discussion 1 02-01-2007 11:13 AM
Oil Leak Duck916 Service, Maintenance and Technical Discussion 7 06-29-2005 05:39 PM
