special oil change procedure, huh ? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-09-2004, 11:47 AM Thread Starter
got a skid plate. that's neat. the SS camaro had none.
anyway, pull the plate off and the flippin' oil pan's got two warnings,wtf ?
special oil fill procedure ?????????????? see service manual ????????????
what's the deal here ?
car's up on stands.
westell is offline
post #2 of 8 (permalink) Old 10-09-2004, 12:06 PM Thread Starter
correction, oil "drain" drain procedure.
anyway, i'm disappointed that there's no magnet on the drain plug.
on both of my LS1's on the camaro SS there was a good amount of metal slivers and metal sludge on the first two oil changes.
some of the guys put that magnet you can put on the outside of your oil filter.
on synthetic now after 500 miles. mobil 1
westell is offline
post #3 of 8 (permalink) Old 10-11-2004, 12:43 PM
Magnetic oil plugs are available at the dealership part counter for about $2.
leaftye is offline
post #4 of 8 (permalink) Old 11-01-2004, 11:54 AM
Any more info on this?
Also, how do you jack up this car for an oil change?
Lorrie Ann is offline
post #5 of 8 (permalink) Old 11-01-2004, 04:08 PM Thread Starter
hi lorrie ann
nothing special after you get the skid plate off.
i jacked my gto up right on the frame, left a little indent, but it did on the SS Camaro, too.
6 qts and yer done
changed the Camaro's for years and as soon as I saw the "warnings", I was like wtf ?
westell is offline
post #6 of 8 (permalink) Old 11-02-2004, 03:36 PM
Don't you have to put in 6 1/2 quarts. I think that's what the manual said.
6 quarts plus 1/2 a quart for the filter.
blue goat is offline
post #7 of 8 (permalink) Old 11-02-2004, 03:59 PM Thread Starter
can only refer to my LS1 SS Camaro. Manual said 5.5 qts, always put in 6.0 and it was a little high on the stick.
Put 6.0 in the GTO and it was right on the full mark.
You can go ahead, imo, put the 6.5, 'cause you'll probably burn 1/2 qt. (normal GM consumption) between next change.
westell is offline
post #8 of 8 (permalink) Old 11-03-2004, 08:55 AM
Send a message via AIM to Whiteshadow
I'd agree, and say 6.5qts is the way to go. Depending on driving style, and how often you change oil. Due to the fact that I will be autocrossing the car regularly, and baffling the oil pan is not legal in stock class, I'll have to run a little more oil in it just to be safe.
Whiteshadow is offline
