Squeaking - Pontiac GTO Forum
post #1 of 11 (permalink) Old 02-06-2013, 02:50 PM Thread Starter
Squeaking
Before I get carried away and spray my motor down with WD-40, is there a product recommended for stopping squeaking coming from the belt assembly? Preferably one that wont leave tons of grease-like residue behind.
Also, where are the common problem areas so I can avoid spraying everything down with the process of ellimination.
Thanks,
Evan
evanpatchay is offline
post #2 of 11 (permalink) Old 02-10-2013, 08:48 PM
YellO5LS2's Avatar
The belt setup on the LS2 in the GTOs is a chronic squeaker. A lot of people on the forum have had good luck with Goodyear Gator belts. I have a Dayco in mine at the moment cause the GM belt is like 160 or something crazy. Mine squeaks after it rains or if its humid. Otherwise it's more or less quiet. But the belt squeak with these cars seems to be commonplace. Don't forget about the AC belt either. That can be the culprit also and it's cheaper than the accessory belt.
YellO5LS2 is offline
post #3 of 11 (permalink) Old 02-10-2013, 08:50 PM
YellO5LS2's Avatar
Thanks,
Evan
Oh yeah, I wouldn't use WD40 on the belts. That's gonna make it squeak more. I'd just roll with it, honestly, unless the belt is cracked and worn.
post #4 of 11 (permalink) Old 02-11-2013, 06:40 AM Thread Starter
okay I gotcha... Thanks for the info!
post #5 of 11 (permalink) Old 02-11-2013, 09:42 AM
YellO5LS2's Avatar
No problem
If its really bugging you though you can spray a small amount (real small) of belt dressing with the engine off. That stuff is sticky so don't rub it over the belt with towels or rags or residue will get on the belt and wear on the pulleys. Let me know what belt you choose, I'll be buying a new one soon, as mine is starting to show age.
post #6 of 11 (permalink) Old 02-11-2013, 10:32 AM
Steamwalker's Avatar
I've tried the belt conditioner stuff - didn't work. I just replaced the belt and squeak went away.
Steamwalker is offline
post #7 of 11 (permalink) Old 02-11-2013, 11:37 AM
HP11's Avatar
Quoted: 24 Post(s)
Belt conditioners/dressings are for V belts to compensate for loss of tension when they stretch or dry out with age (adjustiment would also stop the squeaking on V belts). However, it's pretty much useless on serpentine belts since they have tensionsers.
P.S.: You don't really want to spray down your engine with WD40....it's flamable; both the propellant and the WD40 itself.
HP11 is offline
post #8 of 11 (permalink) Old 02-12-2013, 02:41 PM
jpalamar's Avatar
My Vette squeeks for a minute or 2 when I cold start it on rainy days. My wifes 05 GTO did the same thing. We kinda just delt with it to be honest.
04 GTO - sold
jpalamar is offline
post #9 of 11 (permalink) Old 02-13-2013, 07:52 AM
BWinc's Avatar
I get some squeaks at first start up when there is a lot of moisture in the air. I deal with it. Some people use silicone paste. I know of one person who bought a slightly smaller belt to take are of his chronic squeaking. Not sure if I'd put any extra tension on the pulleys that way.
Current: MGW-p, H-pipe, SS OTRCAI, Lovell rear springs, Eliminator shocks and Pioneer AVH-P3300BT, JBA LTs+catless mids, Drilled/Slotted rotors, Kooks Afterburners, catch can & Tune Next: ??? Wish list: Intake & TB, modest cam, UDP, gears
BWinc is offline
post #10 of 11 (permalink) Old 02-13-2013, 03:05 PM
trues607's Avatar
Re: Squeaking
I have the same thing on my '04. The belt looks fine but will be noisey for about a minute upon start up. I just deal with it.
Sent from my ZTE-Z990G using AutoGuide.Com Free App
trues607 is offline
Squeaking Seat Lukemo2 Interior Discussions 5 01-20-2011 05:19 PM
Squeaking Noise Please Help Bday6262 Service, Maintenance and Technical Discussion 6 05-05-2008 07:47 PM
GTO squeaking issue Samzcool Service, Maintenance and Technical Discussion 7 12-08-2007 03:31 PM
squeaking suspension Bertich 2004-2006 GTO General Discussion 4 04-06-2007 09:13 AM
squeaking busyduck Drive train, suspension, alignment and brakes. 3 07-09-2006 06:45 PM
