Squealing - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-09-2014, 11:56 AM Thread Starter
Squealing
I have a 66 '389 that started a belt squeal ( Sounds like ) I have replaced belts ,taken belt off alternator, and started no squeal ,tested alternator its good , had pullys sandblasted no change . Taken off water pump , power steering belt and left alternator belt on no squeal ? put both belts back on and squelas like a pig anyone have a idea what to do next ????????
rcp driver is offline
post #2 of 3 (permalink) Old 04-09-2014, 02:51 PM
SIXO GTO's Avatar
Any play in any of the bearings ? water pump/alt ps ? sometime when under load from the belt tension the accessories will cant slightly & make noise if the bearings or seal on water pump are worn, otherwise do you have proper tension on the belts ?? make sure all pulleys are inline of each other... a small misalignment will cause the squeal too...
SIXO GTO is offline
post #3 of 3 (permalink) Old 04-09-2014, 07:52 PM
Joe'sToy's Avatar
Is your alternator a chromed one? if it is, then I had a similar experience. Was getting a squealing belt sound every time started the car, changed belts, changed pulleys, nothing worked. Pulled alternator and had it tested. Shop said the chrome had flashed over and that was causing the squealing sounds. Replaced the alternator with a plain none chrome one and the squeal went away! Crazy as it sounds, but now no noise.
Joe'sToy is offline
5.7 squealing Papa Rad Engine Discussions 6 05-10-2012 03:14 PM
whining squealing noise dustyminpin The Lounge 4 07-30-2011 01:43 PM
Any experience with belts squealing? nmiller5000 1964-1974 Tempest, Lemans & GTO General Discussion 5 04-10-2011 11:53 AM
Squealing and Rattling noise 2004bluegto 2004-2006 GTO General Discussion 6 12-20-2010 07:51 PM
Underhood squealing danekejt Service, Maintenance and Technical Discussion 9 08-13-2009 06:55 AM
