Stalling problem during hard exceleration - Pontiac GTO Forum
post #1 of 12 (permalink) Old 09-28-2012, 09:52 PM Thread Starter
danfigg's Avatar
I reused the stock air box but instead of using the drop in filter,I left it off and I used a cone type filter and put it in the opening of the air box. I made sure it was all sealed up and put the elbow back on and tightened everything up. I took the car for a ride and noticed an improved performance feel. I was actually spinning second on a roll. Suddenly after it warmed up I noticed when I punched it the car stalled and when I let off the throttle, it came back to life. I punch it and it stalled again and again when ever I got floored the throttle. Once I let off the throttle, it drives normal. No check engine light. So Im wondering if it is not sealed up as good as I thought, or the computer need to be reset due to the engine receiving air from a different source that its not used to. If it is not sealed properly, I will buy a stock type drop in filter and cut out the rest of the filter and use the seal to properly seal up the box. I dont want to use my K&N filter as the test mule, or the computer does not like the way the air is flowing into the mass air. Im assuming the air inside the box gives an additional pool of air for the engine. Im just wondering what other think could be the problem.I will put every thing back to the way I had it to make sure nothing else is wrong------Danfigg
danfigg is offline
post #2 of 12 (permalink) Old 09-28-2012, 10:51 PM Thread Starter
danfigg's Avatar
re
this is where I put the filter----danfigg
05 IBM M6 summit UDP Vararam OVRAI Dyno tech long tubes W 04/catted mids 04 spintech X-pipe merged into 05 kooks after burners In-tune diablo tuner
danfigg is offline
post #3 of 12 (permalink) Old 09-28-2012, 11:39 PM
646904GTO's Avatar
May I need ask, but did you do anything with the CAI sensor? unplugged?
usually the condition you describe and the changes you made makes it sound like it might be out or unplugged. Just guessin'
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #4 of 12 (permalink) Old 09-28-2012, 11:54 PM Thread Starter
danfigg's Avatar
re
No i plugged the mass air back in. I thought that the plug might be bad as well, but I will check to make sure its plugged in properly----danfigg
danfigg is offline
post #5 of 12 (permalink) Old 09-29-2012, 03:24 PM
you'd get a check engine light with that although it may still come on later. It could be an air leak or oil on the MAF. It's not getting that much of a difference in air to cause a problem. If you still have a problem buy some spray MAF cleaner and carefully clean the MAF sensor off.
post #6 of 12 (permalink) Old 10-03-2012, 03:51 PM
68OldGoat's Avatar
Just a thought.... could it be due to the traction control kicking in? (it fits the symptoms if you are spinning the tires)...try turning traction control off!
68OldGoat is offline
post #7 of 12 (permalink) Old 10-04-2012, 06:02 PM Thread Starter
danfigg's Avatar
re
68 this was a complete stall and and as i let off the gas it comes back. I definately had the TC off. I just got my drop in filter and will seal it all up again and take it for a ride and see what happens-----Danfigg
danfigg is offline
post #8 of 12 (permalink) Old 10-05-2012, 05:49 PM Thread Starter
danfigg's Avatar
re
Problem solved, I used the drop in filter and it ran good. I ripped out the paper element and she woke up. checked all the connections and I also found that the rubber connectto flipped under the clamp and I had an air leak for sure there as well. So now I have a cone type filter at the end of the air box and I used the remainder of the drop in filter without the paper as the gasket to seal the box. I am now getting cooler air from within the bumper and headlights. I will also see if I can isolate that area from getting head from the engine bay as well. Thanks for all your help it definately sent me in the right direction----danfigg
danfigg is offline
post #9 of 12 (permalink) Old 10-08-2012, 10:24 AM
jpalamar's Avatar
I'd return it back to stock. I doubt your getting anything out of that setup.
It just 'sounds' faster.
04 GTO - sold
jpalamar is offline
post #10 of 12 (permalink) Old 10-08-2012, 10:59 AM
I also think you haven't really changed anything. The gains from a filter would be next to nothing and the stock box probably did a better job of isolating air as much as it can be from that placement. There is no significant air coming from the headlight. The stock system uses air from that little vent on the radiator cover and some holes under the box. You're still getting air from the same places.
