Steering wheel controls - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-08-2010, 12:21 AM Thread Starter
does anyone know how to remove the controls from the steering wheel? My right control is broken and needs to be removed...
jakekwil is offline
post #2 of 2 (permalink) Old 03-08-2010, 03:22 AM
AlaGreyGoat's Avatar
FIRST REMOVE THE BATTERY CABLE !!
You are going to pull the air bag out!
Some people also remove the SRS air bag fuses, I didn't.
Remove the cover behind the steering wheel. It clips together
and splits top and bottom.
There are four pins that stick through the wheel and clips
on the back. In the pic, you can see the 4 holes, 2 on each
side of the NOTICE tag and the 2 wider spaced, above.
To release, push the small metal clips toward the outside of the
wheel. You can see them inside the holes in the pic.
Name:	06 GTO Steering Wheel.JPG
Larry
AlaGreyGoat is offline
Steering Wheel Audio Controls Freelancer Interior Discussions 4 01-01-2010 11:12 AM
Stearing Wheel controls w/aftermarker HU Mongoose Interior Discussions 2 06-28-2009 01:26 PM
Short in Wheel-Mounted Radio Controls? d2htornado Interior Discussions 4 06-14-2006 05:13 PM
