Stroker kit for 6.0? - Pontiac GTO Forum
post #1 of 13 (permalink) Old 01-05-2006, 08:40 AM Thread Starter
Anybody done this? Was that a dumb question? Does that net 403 cid?
If 'yes' to the first question, about what whp can be expected w/ these mods:
- Fairly hot streetable cam
- Catted LTs
- Cat-back
- Tune
ModBoss2 is offline
post #2 of 13 (permalink) Old 01-05-2006, 08:48 AM
- Catted LTs
- Cat-back
- Tune
403 cid and upper 400 low 500 rwhp.
GTODEALER is offline
post #3 of 13 (permalink) Old 01-05-2006, 10:55 AM Thread Starter
It's still in the kickin' around stages, but besides upgrading my clutch, will the stock trans, driveshaft and axles handle 500 rwhp w/o fears of breakages? I won't be drag racin' it
I forgot to mention my CAI as one of the mods, but that's not worth a whole lot...
If I do the work myself, I'll add LTs, heads, cam and tune to what I've already done, hoping for around 450/450+ rwhp, but if I let a performance pro do the work, I'll go stroked w/ just LTs, cam and tune...I'll just have to wait and see, and decide when I get a little closer to the actual time that I decide to do this.
ModBoss2 is offline
post #4 of 13 (permalink) Old 01-05-2006, 12:15 PM
The stock drivetrain will NOT handle this much power! Trust me.
post #5 of 13 (permalink) Old 01-05-2006, 12:21 PM Thread Starter
Will it even handle 450 rwhp? A better F/W and clutch isn't a problem, but I don't want to get into upgrading everything from the clutch back. If it won't, I'll stop my mods at LTs and a tune.
ModBoss2 is offline
post #6 of 13 (permalink) Old 01-05-2006, 12:27 PM
450 and less is about it, as long as you don't put drag radials on it or drag race (on a track) you should be okay.
post #7 of 13 (permalink) Old 01-05-2006, 02:22 PM Thread Starter
I won't be taking it to the track and DRs are out of the question...so I guess I'll be safe at the 450 rwhp limit.
One last question, then I'll stop bugging you for a while...without doing the heads, just going with a cam, LTs, cat-back, CAI and tune, how much shy of the 450 rwhp mark will I be? A lot?
I don't even know what a good cam for me would be. I want a pretty hot one that will pull strong in the 2,000 - 6,500 rpm range that's still streetable for a daily driver; don't want one that's happy only on a circle track and has the low-end grunt of a Kia.
I figure you've done enough testing and know what'll work. Maybe around tax return time I'll be able to start getting serious about finishing up on my mods. I hope so!
Thanks,
ModBoss2 is offline
post #8 of 13 (permalink) Old 01-05-2006, 04:48 PM
Thanks,
If I were you I would get with EDC, he's a member of this board and he's a cam guru that will be able to answer that better than me. The old cam that was in the Fatbitch is now in a "cam only" 05 and it made 431 rwhp and 390 rwtq. (he has a K&N cai, SLP longtubes w/high flow cats, Magnaflow mufflers (stock catback w/x-pipe), SLP underdrive, and a custom tune)
post #9 of 13 (permalink) Old 01-05-2006, 07:06 PM
There's a shop in Fort Wayne Indiana I believe that blows goats and claims the drivetrain is good for up to 700 hp safely. Is this just BS then?
MeanGoat is offline
post #10 of 13 (permalink) Old 01-05-2006, 08:46 PM
LYNMUP's Avatar
Originally Posted by MeanGoat
There's a shop in Fort Wayne Indiana I believe that blows goats...
Now that just sounds funny.
'05 QSM M6
LYNMUP is offline
