Stuck Spark Plug Wires - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-28-2014, 11:11 AM Thread Starter
Re: 2004 GTO work car
Hello All:
How do I pull off the spark plug wires from the spark plugs?
It seems stuck, and I do not have leverage to pull off the wire boot from the plug side, within the limited space.
Thank you for your help,
Eric
Eric Sakai is offline
post #2 of 4 (permalink) Old 05-28-2014, 01:00 PM
There are little spark plug pliers but if they are welded on you may still end up replacing the wires. Use dielectric grease on them when you re-install.
post #3 of 4 (permalink) Old 05-28-2014, 07:44 PM
Steamwalker's Avatar
Twist and yank. I think the #7 one was the biggest PITA.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #4 of 4 (permalink) Old 05-29-2014, 09:45 AM
svede1212 is Wright the spark plug pliers are worth their weight in gold and if you get a set make sure they are a good pair I had too buy a second set from snap on because the first set would just bend and not grab
blackhawk571 is offline
Spark Plug Wires vera_jr 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 06-20-2013 02:08 AM
spark plug wires Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 04-07-2011 09:11 PM
Spark plug wires dizzy1 2004-2006 GTO General Discussion 0 05-08-2007 08:34 AM
Removing the Spark Plug Wires Groucho Service, Maintenance and Technical Discussion 14 10-18-2005 01:53 PM
Spark Plug Wires Maximental Service, Maintenance and Technical Discussion 4 02-08-2005 11:15 PM
