Suddenly Lost 4? cylinders--trac off - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-19-2015, 04:02 PM Thread Starter
2006 M6 GTO with 102,000 miles. Changed plugs and wires 2 weeks ago. Only mod is Volant CAI. Driving on the freeway at 75mph, engine suddenly started running rough the TRAC control went off and button does nothing. No check engine light??? Pulled off freeway, engine is missing badly on multiple cylinders on both sides. Disconnected/reconnected battery with no improvement. Drove the remaining way home with the average mileage increasing all the way???? Pulled all plugs and wires--nothing wrong there. Started up and checked temp of each exhaust port/manifold. Cylinders 1,3,2 and 4 are cold. Disconnected and reconnected all the basic connectors with no change. Now have check engine light-flashing. Code set is P0300--Random misfire detected. Any suggestions? Is there a good place or person that is good at trouble shooting these issues/cars here in Phoenix??? Replaced the cam sensor this evening--no improvement
06Ron is offline
post #2 of 3 (permalink) Old 08-26-2015, 02:22 AM
did you verify that those cylinders were getting spark? If they aren't I'd check your coil packs.
r3d05GTO is offline
post #3 of 3 (permalink) Old 08-26-2015, 12:14 PM
Odd that it's the front cylinders of the engine. If it was one side or the other I'd say harness plugs but even then I'd still say it was a spark or injector problem. Were the plugs wet? They should be if there was no spark.
Fitting new wheel cylinders on 67 Tempest DanT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-12-2013 08:26 AM
tachometer suddenly stopped working woolsey10 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 09-06-2012 06:42 PM
Posi trac conversion kit for 71' Lemans SPCMarty 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-10-2011 04:42 PM
04 suddenly running rich Sonny55 Service, Maintenance and Technical Discussion 0 06-30-2011 02:05 PM
Trac Control jobathehut Engine Discussions 25 11-27-2009 12:00 AM
