Switched Hot Lead - Pontiac GTO Forum
post #1 of 11 (permalink) Old 11-21-2005, 08:05 AM Thread Starter
Switched Hot Lead
Any suggestions for a good switched 12V source under the drivers side dash? I hate cutting back insulation on the wires to experiment. I have to wire up the Valentine One and a pro-install kit for the cell phone soon; I am driving 'naked' now.
Pic's would be great, but a simple wire color and general vicinity is fine too.
Thanks.
Red Fred is offline
post #2 of 11 (permalink) Old 11-21-2005, 02:59 PM Thread Starter
nEvErMinD.
I'll just jump a lead from the fusebox... which i thought was on the other side of the dash.....
Red Fred is offline
post #3 of 11 (permalink) Old 11-21-2005, 03:35 PM
I connected my laser shifter here (red wire), it's non fused and switched,
05GTO is offline
post #4 of 11 (permalink) Old 11-21-2005, 05:10 PM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
ouch. that hurt my eyes to look at.
post #5 of 11 (permalink) Old 11-21-2005, 10:29 PM
Rob in CT
Guest
Posts: n/a
Quoted: Post(s)
I put on my glasses and it didn't get better.. :-)
On the 05's isn't there a connector for the center gauges just under the top cover? (I'm assuming this, haven't actually looked)
post #6 of 11 (permalink) Old 11-26-2005, 09:41 AM
Holden's Avatar
Thanks.
This should be good if you donít have front ashtray lighter option. There is a plug behind where ash tray would be can be accessed from suede panel on passenger side of console has 3 male spades inside open connector mounted to back of strut. 1 is fused 20amp marked lighter in box. I use this for several accessories good heavy P.S.. This is off topic but pics will help and WTH is a good link ďhttp://members.cox.net/05gto/Ē
Holden is offline
post #7 of 11 (permalink) Old 11-28-2005, 10:02 AM Thread Starter
Thanks Holden. I couldn't open the URL but the description is good.
I finished the Valentine 1 wiring and put in a pro-install kit for my Motorola phone yesterday. I chased the cigarette lighter wires from the armrest back to the connector behind the shifter and spliced in there. The "brain" fit well in that space under the center console. I was not able to locate the "HI-low" 12V source to activate the phone's auto power function though. Install kit says green wire needs to go to a source that goes HIGH when starter is engaged and remains low afterwards.
Red Fred is offline
post #8 of 11 (permalink) Old 11-28-2005, 11:43 AM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
the website is FULL of info!
post #9 of 11 (permalink) Old 11-28-2005, 07:48 PM
Holden's Avatar
Itís the dang ( ď Ē ) I need to stop that! Ah Iím glad your project went well. But I donít think you understood sounds like you taped into power outlet in console. There is actually another circuit not being used if you donít have smokers kit. There is actually a plug you can just use spades on that is behind cubby compartment behind strut for dash 20amp fuse labeled Lighter not same as power outlet. Power outlet has the accessory power on feature and the Lighter just goes on off with key. Thanks BIG Mike for fixing my link it is good for pics, even if itís off topic
Holden is offline
post #10 of 11 (permalink) Old 11-29-2005, 10:33 AM Thread Starter
I had already tapped into the armrest lighter line before I read your post! It's good to know the other one is there though since I am sure I will be adding other electronics in the car eventually. Thx.
Still curious if anyone has any experience with the HI/LO power source situation.
Red Fred is offline
