System Diagnostic Test - Pontiac GTO Forum
post #1 of 25 (permalink) Old 08-11-2005, 11:13 AM Thread Starter
btchplz's Avatar
Has anyone tried the systems diagnostic test? You are able to enter the computers diagnostic by holding down the mode & set buttons while turning on the car.
There is a bunch of information that it gives like battery voltage, brake voltage, and other useful information but I have a question on specifically the "Trouble Code" portion. On mine it displays a series of "0" for the most part but I do have two "1" listed. This to me means that there must be something wrong in two different areas of the car.
The funny thing is that the car just got serviced by Mr. Goodwrench who failed to mention anything. I checked the car before I gave it to them to service and the same two "1"'s showed and I re-checked it after I got it back and they were not cleared.
I really dislike this dealership because they seem to not know much about the GTO and any questions I have they don't have answers for.
I get most of my answers from fellow GTO owners on this forum.
My question is, can anyone check their systems diagnostic and see if any "1"'s are listed? I am going to take it back to the dealer and ask them but before I do I want to know if anyone else is experiencing something similar.
btchplz is offline
post #2 of 25 (permalink) Old 08-11-2005, 11:41 AM
Will look at lunch and let ya know what I see...
Xcommuter is offline
post #3 of 25 (permalink) Old 08-11-2005, 01:19 PM
There is a bunch of information that it gives like battery voltage, brake voltage, and other useful information but I have a question on specifically the "Trouble Code" portion. On mine it displays a series of "0" for the most part but I do have two "1" listed. This to me means that there must be something wrong in two different areas of the car.question is, can anyone check their systems diagnostic and see if any "1"'s are listed? I am going to take it back to the dealer and ask them but before I do I want to know if anyone else is experiencing something similar.
Had not been here before , so Thanks for the heads-up...
Regarding your question : Two rows of zeros in my case (no ones)...
post #4 of 25 (permalink) Old 08-11-2005, 01:22 PM
Did the last one freak you out? It did me the first time I tried it out, I thought I screwed something up! lol!
gameover is offline
post #5 of 25 (permalink) Old 08-11-2005, 02:01 PM
The last one being the Gauge dial check ? - kinda did , but then remembered it from another threads comments , just at that time didn't understand that thread's comment.
I will be writing this info down and keeping for baseline references...
post #6 of 25 (permalink) Old 08-11-2005, 02:27 PM
I have all zero's on mine. BTW: the brake voltage goes from 2.0v to 0.0 when you raise the parking brake. Not sure why they are monitoring that...
I use the digital water temp all the time at the track. With both fans on high, I can maintain 178-181 degrees with a 160 thermo...
J
Jason Rogers is offline
post #7 of 25 (permalink) Old 08-11-2005, 03:35 PM
Help me out with this, I just went down, started up my car, held onto both the mode and set button, and all I got were the display changes, options menu with volume control, etc. No error code check, or battery /brake display.
Am I missing something?! Thanks,
Dave
huskerGTO is offline
post #8 of 25 (permalink) Old 08-11-2005, 03:43 PM
Hold both buttons, then use your third hand to turn on the ignition.
post #9 of 25 (permalink) Old 08-11-2005, 03:44 PM
Dave
Hold the mode and set button down , and then start the car . As I remember the mode button will cycle you thru the different readings...
Yea I thought this procedure was ackward too but worth the twisted wrist.
post #10 of 25 (permalink) Old 08-11-2005, 03:45 PM
J
If you ever noticed, your DRL's do not come on until you release the parking brake upon the first start. When you put it back on they do not turn off though. Anyway, that may be what they are using that input for.
JMVorbeck is offline
