System Voltage - O6 GTO - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-15-2006, 06:34 PM Thread Starter
Have the Guage Pod installed. Did no calibration work to it. System is reading about 13.8- 14.0 Volts. Seems highish. Anyone else?
Never mind - digital volt meter and RD both call out the same voltage as the guage.
bg2m8o is offline
post #2 of 8 (permalink) Old 10-15-2006, 08:34 PM
bergenfelter's Avatar
13.7 volts is the normal operating voltage.
bergenfelter is offline
post #3 of 8 (permalink) Old 10-18-2006, 09:04 AM
normal charging system voltage on any vehicle is 13.5-15.0 volts, any lower and you have a weak alternator, higher would indicate a faulty voltage regulator in the alternator.
silver04G-T-OHHH is offline
post #4 of 8 (permalink) Old 10-18-2006, 09:08 AM Thread Starter
Thanks guys - I engaged mouth before brain
bg2m8o is offline
post #5 of 8 (permalink) Old 10-18-2006, 03:18 PM
yeah that happens to me all the time, usually pisses the g/f off more than anything
post #6 of 8 (permalink) Old 10-20-2006, 02:25 AM
do the hold the mode and set button while turning your car on trick and scroll through to the voltage,,,,you can set it up exact that way
flyer469 is offline
post #7 of 8 (permalink) Old 10-20-2006, 01:32 PM Thread Starter
You guys are all dead on. Like I said mouth first, then brain. Happens to me a lot. Most times the brain works, but sometimes it's just the mouth. DAMN
bg2m8o is offline
post #8 of 8 (permalink) Old 10-20-2006, 01:38 PM
raven1124's Avatar
Send a message via Yahoo to raven1124
Ha! Y'all are so right.
raven1124 is offline
