Tachometer hangs - Pontiac GTO Forum
post #1 of 9 (permalink) Old 10-26-2015, 10:11 PM Thread Starter
Quoted: 6 Post(s)
Tachometer hangs
Hello - I have 2005, LS2 4sp auto. (Just bought it used w/ 40k miles on it a month ago) I noticed in 1st, 2nd, or 3rd but not in "D", when I run the speed & revs up but then hit the brakes, the tach will hang. Ex., in 2nd gear, I run it up to 60mph and tach is around 4,000 if I let off the gas or it hit the brakes it hangs at 4,00 revs for several seconds before it slowly drops. Is there something else like a vacuum line interconnect with the tach? (Makes no sense but I'm struggling to determine why it would hand in every gear but Drive.
TIA for any insights.
Goat51
Goat51 is offline
post #2 of 9 (permalink) Old 10-27-2015, 07:31 AM
HP11's Avatar
Quoted: 24 Post(s)
Is the engine actually hanging at 4000 rpm then dropping or is the tach just sticking at 4000 rpm the dropping?
HP11 is offline
post #3 of 9 (permalink) Old 10-27-2015, 12:04 PM Thread Starter
Quoted: 6 Post(s)
Hanging tach
thanks - the engine revs drop...the motor is running great, no problem there... the tach hangs or sticks. Again it'll stay for several seconds, then slowly go down to 500 rpm (at idle if I come to complete stop)or where the engine revs are at. (hope that helps)
Goat51 is offline
post #4 of 9 (permalink) Old 10-27-2015, 03:39 PM
HP11's Avatar
Quoted: 24 Post(s)
I had an answer if the engine itself was hanging but someone else will have to chime in about the sticking tach as I've never experienced that one.
HP11 is offline
post #5 of 9 (permalink) Old 10-28-2015, 11:56 AM
Sounds like it's mechanical in the cluster.
post #6 of 9 (permalink) Old 10-29-2015, 01:27 PM Thread Starter
Quoted: 6 Post(s)
Well thanks for the brain time on this gents. It's weird and I'll keep you posted with any updates.
## after further acceleration tests, it hand in "D" too. I bet as mentioned its the Cluster or a cluster feck.
It'll wait tell next year because really, its no biggie. thanks guys
Goat51 is offline
post #7 of 9 (permalink) Old 10-29-2015, 02:03 PM
I've heard of other GM cars/trucks with gauge issues (speedo not working, gas gauge wigs out) that can be repaired but never on the GTO.
post #8 of 9 (permalink) Old 10-30-2015, 07:11 AM
johni53's Avatar
Apologize for the hijack but my engine does actually hang for a moment sometimes, all the times at startup. At about 2000 rpm for a few seconds. Is it just a sticky throttle wire? What's the fix?
1-7/8" ARH LTs, 3" Magnaflow exh.,Spec twin disc clutch, 402 stroker , Fast 102 w/Nick Williams TB, 1000 hp shaft & axles, cam, fuel & suspension upgrades. 500 rwhp, 484 rwtq
johni53 is offline
post #9 of 9 (permalink) Old 10-30-2015, 07:30 AM
HP11's Avatar
Quoted: 24 Post(s)
Never had the problem on the GTO but on another drive by wire vehicle we owned the problem was solved by replacing the accelerator pedal sensor.
HP11 is offline
65 tachometer wiring geraldb999 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 05-08-2019 08:16 AM
Tachometer 66 gto Dmangto 1964-1974 Tempest, Lemans & GTO General Discussion 7 02-01-2014 10:57 PM
Tachometer wire SIXT5GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 01-08-2011 10:44 AM
Tachometer wimtexdoc 1964-1974 Tempest, Lemans & GTO General Discussion 2 10-06-2009 02:50 PM
