Tail Light Issue on 2005 - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-29-2015, 09:02 AM Thread Starter
vance_pounders's Avatar
Morning everyone,
I am having an issue with my passenger tail light. When driving both tail lights are working. However, when I apply my brakes the passenger tail light goes out.
I've tried looking through the manual to see if there is anything that could help but was unable to locate anything.
Has anyone has this issue or know what i should look into?
vance_pounders is offline
post #2 of 3 (permalink) Old 04-29-2015, 10:35 AM
HP11's Avatar
Quoted: 24 Post(s)
Had this problem on my Ford Ranger but it has to be similar. It turned out to be a bad ground on that side. (Drivers side in my case) The tail light and brake light circuits are both grounded when they're off. One will find a ground through the other as long as only one is on at time. When you hit the brakes, both circuits are on, you have no ground so every thing goes off. I fixed it by replacing the socket.
HP11 is offline
post #3 of 3 (permalink) Old 11-26-2015, 06:35 PM
I had the same problem. Mine was the actual bulb connector. I had to disconnect my battery and pry the small contacts out that are inside of the socket where the bulb goes...PLEASE DISCONNECT THE BATTERY OR YOU WILL BE REPLACING FUSES OR WORSE.
G.. T.. O is offline
'66 GTO head light switch/ tail light problem trialsmm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 01-25-2016 01:22 AM
1968 Rear Tail Light Assembly issue? Have 69 Bumper with 68 Lights Pstamato 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 14 01-01-2016 09:18 AM
Dashboard issue with tail light LED install 6LGTO Interior Discussions 6 08-28-2014 08:57 PM
tail panel / tail light bezel ideas 44070dart 1964-1974 Tempest, Lemans & GTO General Discussion 6 05-27-2012 02:59 PM
