Threw both P2176 and P2135 TPS and APP sensors - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-15-2014, 09:14 AM Thread Starter
I'm now the proud owner of a 2005 Goat unfortunately I haven't wanted to drive her much because I often get thrown the faulty TPS and APP sensor codes but then my engine will clear the code after a while and so my question is what is the reason these two trip simultaneously and why does my engine seem to clear this code after a few hours
RoaringGoat05 is offline
post #2 of 4 (permalink) Old 07-16-2014, 08:55 AM
Ah the drive by wire blues. I love my cable TB. It's throwing both because the computer is seeing a difference in the TPS signal and what the TB sensors are seeing. It can be as simple as a connection, the throttle position sensor, TB or even the ECM. You could check the connections, see if the TB bade isn't sticking for some reason, replace the pedal sensor or take it to the dealer. The sensors in the TB are intrgal so you'd have to replace the whole thing and they are expensive so it isn't something you would just try. If it's intermittent it can clear itself.
post #3 of 4 (permalink) Old 07-16-2014, 04:22 PM
Wires chaffing behind the glove box cause this?
post #4 of 4 (permalink) Old 07-16-2014, 05:15 PM
I don't think so. It's not the BCM but the ECM that's involved with this code
Tps Lanceth101 Engine Discussions 1 11-18-2013 08:41 AM
Transmission? TPS? You Decide badgoat91 Service, Maintenance and Technical Discussion 3 07-31-2009 11:22 AM
dyno app DeuceDaProdeuca 2004-2006 GTO General Discussion 64 07-18-2009 01:54 PM
Tach and TPS wires at ECM? Cadsbury Service, Maintenance and Technical Discussion 2 12-15-2005 02:48 PM
