Throwing up antifreeze - Pontiac GTO Forum
post #1 of 6 (permalink) Old 07-12-2018, 06:44 PM Thread Starter
Hello. I have a 2006 GTO M6. Let me start from the beginning. I had a coolant leak from the tank on the original radiator, so I replaced it with an orielly radiator. I later plan on getting a nice all aluminum one that will fit with my Vararam CAI. Anyways, I took my car to the drag strip and made a pass, and when I had gotten back and shut it off. I noticed antifreeze on the ground. The car was a little hotter than normal. I waited for it to cool down added water then drove home fine. Today I was driving home from work stopped at Lowes. When I came back out I noticed antifreeze on the ground. I wasn't far from home. So I started it up and began driving home. I noticed the temperature gauge rose above the normal temperature and I pulled over. Right as I was about to shut it off the temperature gradually drop to normal operating temperature. Do you guys know what is causing this?
Sean Harris is offline
post #2 of 6 (permalink) Old 07-12-2018, 10:13 PM
Quoted: 78 Post(s)
Most likely the radiator. My AutoZone replacement lasted about 6 months. Ordered aluminum radiator from GTOG8TA dot com and put the matter behind me. Radiator was a direct fit. Minor issue with the brass drain petcock with its tabs that had a clearance problem with the fan shroud. Instead of trimming the shroud, just bend the ears on the drain valve so it can turn without hitting the shroud.
Now the car is called "Cool Thunder (...from Down Under)"
Shake-N-Bake is offline
post #3 of 6 (permalink) Old 07-13-2018, 07:31 AM
HP11's Avatar
Quoted: 24 Post(s)
Did you properly bleed the cooling system after changing the radiator?
HP11 is offline
post #4 of 6 (permalink) Old 07-13-2018, 11:30 AM
Quoted: 78 Post(s)
^ this is a good suggestion.
I missed the part where the system cooled back down after running warm. Air in the system could cause that symptom...
post #5 of 6 (permalink) Old 07-13-2018, 03:30 PM
HP11's Avatar
Quoted: 24 Post(s)
Yeah, I went through that when I changed the thermostat.
HP11 is offline
post #6 of 6 (permalink) Old 07-20-2018, 09:46 AM
68OldGoat's Avatar
Yes, getting the air out after replacement is a must. To check this, run your heater on warm up. If the heater gets hot, the radiator should be bubble free.
I went with a Mishimoto as a direct fit and it works perfect with my 06 M6. The aluminum radiator from GTOG8TA looks like it is for an auto transmission with the extra trans cooler inlets and outlets on the GTOG8TA. Make sure you get the new one for a manual tranny.
68OldGoat is offline
Throwing Belts and Shifting Gears sspano01 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 08-23-2013 10:14 PM
2005 Throwing up code P0604 (Control Module RAM fault) rezarxt Service, Maintenance and Technical Discussion 6 08-04-2012 10:23 PM
walking/throwing belts! whats going on? motoristx Service, Maintenance and Technical Discussion 18 06-20-2010 04:05 AM
HELP!!! Engine is throwing a fit!! WanaGTO Engine Discussions 3 05-27-2009 01:34 PM
"Throwing codes" Taka2005 Service, Maintenance and Technical Discussion 2 10-16-2005 01:46 PM
