Is it time for a coolant flush? - Pontiac GTO Forum
post #1 of 37 (permalink) Old 09-12-2012, 03:04 PM Thread Starter
iwant2buyaGTO's Avatar
Hello. I noticed my coolant to be a little low. Its just below the cold fill line. I haven't seen a recent post about coolant on here so im asking if i should just add some Dex-Cool to it? Or do i need to do a flush? its been at least 2 years since i haven't touched it. Thanks again
04 Pontiac GTO
35,000 miles
http://img704.imageshack.us/img704/7973/gtoforum.jpg
iwant2buyaGTO is offline
post #2 of 37 (permalink) Old 09-12-2012, 04:25 PM
HP11's Avatar
Quoted: 24 Post(s)
According to the manual, it's every 5 years or 150,000 miles; whichever comes first.
HP11 is online now
post #3 of 37 (permalink) Old 09-12-2012, 04:45 PM Thread Starter
The car is 8 years old. i got it 2 years ago used. Im assuming the previous dealer didnt do it but im not sure. So i think it would be best to do a flush
post #4 of 37 (permalink) Old 09-12-2012, 05:02 PM Thread Starter
Anyone know of a link where it shows step by step how to do a flush. Sorry its my first time. i just purchased this. Whats the difference between this and the 50/50
post #5 of 37 (permalink) Old 09-12-2012, 07:43 PM
HP11's Avatar
Quoted: 24 Post(s)
The 50/50 is already diluted with water. The regular Dexcool is full strength and need to be mixed with water. I've always thought that the 50/50 was a rip-off.....
HP11 is online now
post #6 of 37 (permalink) Old 09-12-2012, 07:55 PM
You late model GTO guys still run that Dex Cool? In the "GTP World" that **** is always flushed out and replaced with conventional "green" antifreeze. Dex Cool causes all kinds of problems with clogging the cooling system and tearing up seals on the intake manifold. Just curious.
post #7 of 37 (permalink) Old 09-12-2012, 08:32 PM
Red1970GTO's Avatar
Depends on the price of the 50/50 compared to 100. You do not want to use tap water to cut Anti Freeze.
Red1970GTO is offline
post #8 of 37 (permalink) Old 09-12-2012, 09:47 PM Thread Starter
So i have to put as much as diluted water as coolant?
post #9 of 37 (permalink) Old 09-12-2012, 11:02 PM
HP11's Avatar
Quoted: 24 Post(s)
Unless the price of the 50/50 is at leat half the cost of the 100%, which it never is, the 100% is a better buy. Unless the water where you are is crap, it really doesn't matter. I've mixed tap water with antifreeze all of my life (and that's a long time!!) and I've never had it cause me any cooling system related problems.
HP11 is online now
post #10 of 37 (permalink) Old 09-13-2012, 08:02 AM
Not true.
Clogging: Many think the sludge in the overfill is a breakdown of DEXCOOL when in fact its a rust inhibitor placed in there at factory to prevent corrosion, and to keep the internal workings of the water pump etc lubricated.
Many panic and say OMG the coolant has broken down. They flush this additive all out and replace with conventional anti-freeze. After a while things start happening to their radiator and other parts associated with cooling. Many come in here seeking answers to why did my radiator blow? Why did this happen? You ask them did you replace the DEXCOOL? The common denominator to most answers are: YES my radiator had sludge in it from the DEXCOOL and I replaced with conventional Anti-Freeze.
The owners manual clearly states use ONLY DEXCOOL. My 2004 Grand-AM says use only DEXCOOL.... My 2007 Doge RAM says use only: MOPARS version of DEXCOOL.
Little ironic its the GTOS using this new formatted coolant that has all these issues isn't it?
Many are ignorant of the proper additives for this car, from DEXCOOL to synthetic oils to F.M. in the rear end.
The only issues I see are from those who are not properly maintaining these cars. MOSTLY 2-4th owners of the car.
Tearing up seals? These motors are designed to be using DEXCOOL. Maybe the seals some are reporting being torn up is being done so by improper coolants or other factors.
Many know it alls on these cars who post their authorivite knowledge on them turn out to be shall I say less than astute on them.
USE DEXCOOL ONLY.... on this new GTO....
My '70 or older cars? NO!
Whenever in doubt ...... read the friggin manual.
Need to flush old auto oil out or not fiesta62 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 12-16-2011 09:15 AM
PS fluid flush/exhchange Poncho Dan Service, Maintenance and Technical Discussion 1 06-19-2011 09:43 AM
Coolant Back Flush?? UdnUdnGTO Service, Maintenance and Technical Discussion 2 08-28-2009 10:08 AM
I need a radiator flush Poncho Dan 2004-2006 GTO General Discussion 5 08-19-2009 09:44 AM
