Tire Pressure? - Pontiac GTO Forum
post #1 of 14 (permalink) Old 10-28-2005, 05:13 PM Thread Starter
2006GTOLS2's Avatar
Tire Pressure?
What tire pressure do you guys run in your GTO? The owners manual states 30psi for(17" wheels)...is this optimal? I have always ran 35....but this morning, after reading more of the manual last night I decided to decrease to 30....can't really tell much of a difference though. Any thoughts?....Thx...
2006 Spice Red M6 - Stock
2006GTOLS2 is offline
post #2 of 14 (permalink) Old 10-28-2005, 06:28 PM
Its higher for the 18's but I just run what it tells me to run. Works fine. I of course will be dropping it a good bit at the track on Sunday. Maybe 25-ish. I want 12's.
slonlo_350 is offline
post #3 of 14 (permalink) Old 10-29-2005, 05:42 AM
18"s are supposed to be 33psi front and 39psi back for the Bridgestone Potenzas.
Pennsylvania Goat is offline
post #4 of 14 (permalink) Old 10-29-2005, 11:29 AM
running at to high a pressure will make for a more harsh ride and incress the posibility for a blow-out at higher speeds.
dealernut is offline
post #5 of 14 (permalink) Old 10-29-2005, 11:46 AM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
I may be old school but dropping tire pressure on a stock street tire is never a good idea. What ends up happening is the center buckles up and provides less traction to the pavement. The best thing to do for more traction on a street tire is to redirect the weight in the car. Take out the passenger seat and rear seats, and put a sandbag in the trunk. Overall the car weighs the same but you have now moved it to the rear and the car will hook MUCH better.
post #6 of 14 (permalink) Old 10-29-2005, 04:16 PM
i have 17's and run 35 in all four. that is also what sticker on door says
JMJ80 is offline
post #7 of 14 (permalink) Old 10-29-2005, 07:07 PM
Warren11050 is offline
post #8 of 14 (permalink) Old 10-30-2005, 09:14 AM
Rule of thumb is this : Follow the tire pressure recommendations that are on the sticker in the door jam. This is the PSI you should go by.
Removing all your seats and putting sand bags in your trunk won't help any of your passengers.
post #9 of 14 (permalink) Old 10-30-2005, 10:28 AM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
if your at a racetrack, you wont have passengers anyway, its against the rules! My suggestion was merely for a racetrack situation only.
As for what the sticker says, that is merely a recommendation by the manufacturer. Its best to play around with the air pressure for your particular driving habits. I used to run 42 in my camaro because I was a hard driver in corners. At 35, I was wearing the outside edges too badly, at 42 it was even wear.
Experimenting never hurt anyone.
post #10 of 14 (permalink) Old 10-30-2005, 12:35 PM
If you still have the stock Goodrich 17's running 35 or 36 is a good idea. If you have them you already know the tires are terrible and wear out quickly. They started putting the same type tire on some model Cadilacs and are getting 6000 miles max out of them.
roadracer is offline
