Traction control came on in neutral/clutch slip? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-20-2013, 04:40 PM Thread Starter
Hey guys,
My M6 '05 GTO (67k) has done a few strange things recently. Once, I revved it up in neutral (to about 3.5K), and the traction control warning came on for a second. Whats up with that? It has never done this before...
Then, today, when I was accelerating away from a stop sign in 1st, there was a slippage (From clutch???) and the traction warning came on again. THe "Loss of traction" only comes on for a second, and the car drives completely fine with the exception of a slight clunk in 3rd. And it was not a launch, but a very controlled, "normal" start from a stop. Was not attempting anything "sporty". It was not the tires slipping either. It was something in the drivetrain.
Recently done: One piece aluminum driveshaft from DSS. Related??
Throws no codes, drives completely normal aside from a slight buzz in exhaust. Only mods are K&N drop in, SLP exhaust, and the driveshaft. I think it might be the factory clutch as well.
Any help would be greatly, greatly appreciated.
Hoonthatsc is offline
post #2 of 2 (permalink) Old 08-20-2013, 11:37 PM
one piece driveshaft
I recently have replaced the factory driveshaft with a one piece aluminum, and it seems the rigidity of the aluminum has an effect on the traction control system sometimes. My Goat has a very heavy clutch, so often on accident, i'll dump it too quickly causing a shock to the rear end, and when that happens, I get a little wiggle. This causes my traction control to kick in when i'm WOT. I don't typically notice in first or second, because most of the time Its spinning the tires if I'm WOT, but when I short shift to third and it starts to wiggle, the traction control will not kick out until I let up. I also notice the problem if i'm cruising at a consistent speed and I jump on it real hard. Seems to give me that wiggle and kicks the traction control In.
taylorjones_11 is offline
Traction Control always off? Akholde 2004-2006 GTO General Discussion 3 10-09-2013 03:30 PM
Traction control light in neutral khurst 2004-2006 GTO General Discussion 3 12-07-2011 01:25 PM
Traction control, still no traction :-) tummen 2004-2006 GTO General Discussion 14 08-22-2008 12:25 PM
traction control 2fas4u428 2004-2006 GTO General Discussion 7 07-21-2008 07:24 AM
Traction Control XGTO Racing and Kill Forum 3 03-04-2006 12:32 AM
