"traction Control Is Off" - Pontiac GTO Forum
post #1 of 12 (permalink) Old 07-01-2007, 02:49 PM Thread Starter
CPO's GTO's Avatar
I noticed today that my traction control is off and I can't turn it back on.
I know, I know...So what, right? But since I haven't done any mods (just a CAI a year ago) I'm wondering what could be causing it. Has any one else seen this before? I have not tried resetting the computer yet. Just thought I would ask around first. I can think of worse things to go wrong, that's for sure!
1 of 370 Black Metallic/Red/Manual/18"
80U 756 MN6 N87
CPO's GTO is offline
post #2 of 12 (permalink) Old 07-01-2007, 03:08 PM
GM4life's Avatar
In your DIC it says "Traction Control OFF"? My only guess is to disconnect the battery and see what happens, if not visit the dealer.
GM4life is offline
post #3 of 12 (permalink) Old 07-01-2007, 07:22 PM
Oh I can't wait to find out what you gotta break to make that happen.
SloTymer is offline
post #4 of 12 (permalink) Old 07-01-2007, 08:39 PM
had same problem on my 04. dealer replaced cluster gauges three times.
Finally blamed it on a short in the wiring harness. I have a 05 now.
rambogto is offline
post #5 of 12 (permalink) Old 07-01-2007, 09:05 PM
have you tried to see if it engages even though it claims to be off? sounds like a warranty issue which there shouldn't be any trouble getting that solved. good luck and try the traction control out in a safe and controlled environment. (block off the highway from traffic and go at it)
koman is offline
post #6 of 12 (permalink) Old 07-01-2007, 09:13 PM Thread Starter
CPO's GTO's Avatar
I should try that. I believe it will still engage, but I'll have to find the right time/spot to find out . First, I will try to reset the computer by disconnecting the battery. I once had a phantam check engine light that
just appeared for no reason. I reset the computer and it was gone and never came back. Thanks for all the replies. My dealer is good, but I don't
want to take it to them unless its the last resort. I'll post up when I find out something.
80U 756 MN6 N87
post #7 of 12 (permalink) Old 07-02-2007, 12:36 AM
CHECK U'R LIGHTS MAKE SURE THERE PLUGGED IN I UNPLUGGED MY TAIL LIGHTS AND MY "TRACK OFF" WAS ON TILL I PLUGGED THEM BACK IN.
damn caps
1badbrazen is offline
post #8 of 12 (permalink) Old 07-02-2007, 12:42 AM
b_a_betterperson's Avatar
Since the default with the system is to have the T/C on, there's definitely something with the computer system. Try a reset. If not, have the dealer look at it. Suppose you could check the wiring for the switch, as gaining access to it is really, really easy, but I don't think it will doing anything...
b_a_betterperson is offline
post #9 of 12 (permalink) Old 07-02-2007, 07:24 AM
I had the same problem in reverse- my T/C wouldn't disengage. It turned out to be nothing more than a bad switch (the one on the console) which the dealer replaced under warrantee.
06 Impulse blue, M6, 17"
69 LeMans vert, stock-looking 455-powered "sleeper"
74 455 TA, HPP magazine cover car
PontiacGuy is offline
post #10 of 12 (permalink) Old 07-02-2007, 01:33 PM Thread Starter
CPO's GTO's Avatar
Hmmm, that sounds interesting. I wonder if its the switch. I'll
try a reset and then back to the dealer if that doesn't fix it.
I need to use one of my free oil change coupons anyway!
Thanks.
80U 756 MN6 N87
