Tranny Fluid for and M6 - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-12-2011, 10:14 PM Thread Starter
YellO5LS2's Avatar
Just wanted to run a question by anyone with the manual transmission. Im switching all my fluids to amsoil and just wanted some input from people who have used an amsoil lubricant in their tranny. I know the Goats want ATF but amsoil advertises two different fluids for the manual and automatic transmissions in the GTOs.
What's the best ATF product to put in the manual trans?
YellO5LS2 is offline
post #2 of 3 (permalink) Old 01-13-2011, 02:02 PM
I would use their ATF fluid, since that's technically the OEM spec. The other fluid they advertise I believe is intended for extreme service, like high temps, which a manual trans isn't subject to nearly as much as a slushbox.
I put some of AMSoil's ATF in my Grand Am @ 80,000 miles. I got 1 more MPG highway average, and I no longer have the hard shifting problems (in a manual) in the extreme cold like I used to.
Poncho Dan is offline
post #3 of 3 (permalink) Old 01-13-2011, 08:32 PM Thread Starter
YellO5LS2's Avatar
Awesome! I know what i'm ordering then...good to know too cause the other stuff is more expensive. Would you recommend changing the fluid via the back up switch or the fill plug? The manual says to use the back up switch but i wasn't sure if that requires a hand or drill pump. Any suggestions as far as getting new fluid in?
Changing Tranny fluid Cobra126 Service, Maintenance and Technical Discussion 10 11-30-2009 08:50 AM
tranny fluid v8newb Service, Maintenance and Technical Discussion 0 02-28-2009 02:52 PM
Recommended tranny fluid? Intouchsean 2004-2006 GTO General Discussion 2 12-25-2008 09:20 AM
Tranny fluid question Russ2005 Drive train, suspension, alignment and brakes. 13 03-07-2006 12:20 PM
tranny fluid leaking redgoat 2004-2006 GTO General Discussion 2 10-20-2005 09:50 PM
