Tranny problem - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-09-2006, 08:33 AM Thread Starter
Tranny problem
So i have an '06 GTO with the M6 and i have noticed a problem that is getting worse. When starting from a stop in either 1st or 2nd depending on driving conditions it sometimes knock the shifter into nuetral when i'm not holding it in gear. This can happen several times a day around town or sometimes not at all. This sounds like worn gears to me but there is no way they can be worn with under 5,000 miles. Has anyone else had this problem?
Chevypowered is offline
post #2 of 5 (permalink) Old 07-09-2006, 11:40 AM
yep my 06 manual likes to pop out of first quite often so now i always hold it when in first
KC.MO.GTO is offline
post #3 of 5 (permalink) Old 07-09-2006, 05:17 PM
Robertr2000's Avatar
Take it to the dealer. That is not normal operation.
Spice Red 06
11/05 build
VolantCAI
IXiridium Plugs, 10.4 Taylor
GMM
Pedders StreetII+ (1/2" drop)
Hotchkins Swaybars
Full AMSOIL & RP
JBA Shorties/Cats
MagnaFlow w/Xpipe
soon: DBA 4k XS Rotors, RedStuff
Robertr2000 is offline
post #4 of 5 (permalink) Old 07-10-2006, 10:11 AM
Shifters popping out of gears is normally a synchronizer issue.
Many years ago I had a VW Beetle (old style) that popped out of 4th gear. At first I could hold it with light pressure, and it stayed in; it eventually got to the point I wasn't strong enough to hold it in- - crazy.
noz34me is offline
post #5 of 5 (permalink) Old 07-20-2006, 09:29 PM Thread Starter
they are going to try and replace some springs in the shifter and see if it helps, but i think its a bigger issue than just some springs, we'll find out.
