Transmission Fluid maintenence on '05 A4 - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-05-2011, 04:31 PM Thread Starter
I just passed the 50,000 mile mark on my '05 A4 GTO. The manual recommends you change the transmission fluid at this time. On an automatic is it really necessary? No leaks, and it shifts great. If so, what kind of fluid do you recommend besides what is recommended by the manufacturer?
Thanks!
RunksGoat is offline
post #2 of 4 (permalink) Old 02-06-2011, 12:43 PM
I'd think for the severe duty these cars typically see, a full fluid exchange (trans "flush" in laymans terms) would be good preventative maintenance at even 25,000 miles. Draining the pan/changing the filter only gets out about 1/3 to 1/2 of the fluid on any given auto trans.
You can't go wrong with AMSoil's ATF. I think the upper temperature limit on that stuff is something like ~390F before it breaks down, well over 100 better than standard dino ATF. It also remains more fluid at colder temperatures, making the trans shift better at cold temps. It made a heck of a difference even in the manual trans in my DD.
Poncho Dan is offline
post #3 of 4 (permalink) Old 02-08-2011, 07:54 PM Thread Starter
Thanks for the reply and suggestion. Is a frans flush something you can do yourself or should that be taken in to do? I figured I would just drain, replace, filter, and put new fluid in but if you say it only gets out about 1/2 of the fluid not sure I want to even waste my time!
post #4 of 4 (permalink) Old 02-09-2011, 10:38 AM
HP11's Avatar
Quoted: 24 Post(s)
Take it to a shop unless you have some type of fluid recovery/exchange equipment at home.
HP11 is online now
Type A transmission fluid? rboman32 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 07-07-2010 03:36 PM
Transmission Fluid HELP!! Falco21 Service, Maintenance and Technical Discussion 6 05-26-2010 09:39 PM
Transmission Fluid Amount. New conflicting information. 06goatm6 Service, Maintenance and Technical Discussion 1 02-12-2009 10:56 PM
Changing transmission and diff fluid - What tools do I need? 04m6_ca Service, Maintenance and Technical Discussion 1 09-29-2005 10:20 AM
