Transmission Question - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-25-2005, 08:37 PM Thread Starter
I have an 05 6MT. Noticed a whirring noise in transmission/clutch, most prevalent during the CAGS forced 1-4 shift at low rpm. I can also hear it more faintly while cruising slowly in 1st or 2nd gear. At first I thought it was the ventilation fan running, same sort of sound but coming from below the shifter area. Other 6MT people experience this?
Sorry if it has been adressed before, couldn't locate with search.
Greg
ncgoat is offline
post #2 of 6 (permalink) Old 11-06-2005, 07:18 AM
Similar sound in my 04
I just got an 04 GTO w/ 23K miles on it last week and I notice a grinding/whurring sound in 2nd gear accompanied by a loud engagement into 3rd. The dealer told me this was normal, but I think he was just trying to brush me off.
GTOgator is offline
post #3 of 6 (permalink) Old 11-06-2005, 08:24 AM
GNX231's Avatar
the t-56 trans is very rugged and makes some noise just like the old m22 rock crushers
GNX231 is offline
post #4 of 6 (permalink) Old 11-06-2005, 11:29 AM
You are probably hearing the synchronizers doing their thing.
As for durability of the T56.....yes probably, but smoothness.... definitely not it's clunky.
Wing_Nut is offline
post #5 of 6 (permalink) Old 11-06-2005, 11:54 AM
I smoked a T56 at 30k miles...replaced under warranty.
The durability of the T56 is vastly overrated.
Groucho is offline
post #6 of 6 (permalink) Old 11-06-2005, 06:52 PM
I'm thinking you are hearing what I started experiencing about 3 weeks ago.. when i depress clutch and shift gears (at least 1/2 2/3/ 3/4 ) at about 4000rpms i get a noise i thought was a through out bearing or something,,, you hear it spinning down .. dealer looked at it and took the tranny apart and inspected everything.. talked to engineers.. engineers didn't know and suggested i shift at the shift points in the manual (yeah right and i'm never going to exceed the speed limit either).. i put rp in and that made no difference in sound but shifts like butter now.. i'm beginning to think like the 2 mechanics it's coming from the cooler line.. it's more like from the side of the tranny (passenger's side) than inside the tranny it seems... If y'all figure it out please post...
goatsandstrats is offline
