Tricks to replacing tail light twist on socket??? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 04-26-2014, 05:22 AM Thread Starter
silversport's Avatar
I noticed the driver's side twilight was out so I picked up a new 1157 bulb...unscrewed the two philips head screws, popped out the twilight housing and then twisted the socket to removed it from the housing...it didn't want to come out.
I was able to persuade it a little help from a blade screwdriver...easily replaced the bulb that had blown and tried to twist the socket with the bulb back into the housing...no can do...
I understand you have to line up the right side tabs on the socket with the right sized slot in the housing but it does NOT want to go in...nor does trying to push it to get it started...
...anyone know what I am doing wrong or have any tricks or tips for re attaching the socket to the housing???
Bill
**QSM/RH/A4/17**1 of 52**
silversport is offline
post #2 of 7 (permalink) Old 04-26-2014, 02:40 PM Thread Starter
60 views and nothing...nobody has had this issue???
Bill
post #3 of 7 (permalink) Old 04-27-2014, 06:40 AM Thread Starter
I guess I am the only one...
post #4 of 7 (permalink) Old 04-27-2014, 01:01 PM
HP11's Avatar
Quoted: 24 Post(s)
After seeing this, just for sh!ts and grins I went out and checked mine. I unscrewed the two screws, pulled it off the two tabs and it twisted right out and then back in. I don't know what to say........
HP11 is online now
post #5 of 7 (permalink) Old 04-28-2014, 06:40 AM Thread Starter
thanks...it has me stymied...
Bill
post #6 of 7 (permalink) Old 04-28-2014, 10:11 AM Thread Starter
HP11...thanks for your response...my passenger side worked as it should but...
took it to the local garage...they saw it clearly had warped from heat (melted)...I didn't notice as the plastic was not discolored...a little more reaming and it fit...however...I still have a problem as the bulb is much brighter now than the passenger side and yes, I exchanged that bulb for a new one too...with no issue with that socket coming out of the housing...
it looks as if the brake light is on for the driver's side and I bet that's what happened that overloaded the bulb...I imagine that I'll need to replace the socket itself and check the wiring to ensure it isn't that...thanks for the responses guys...
Bill
post #7 of 7 (permalink) Old 04-29-2014, 05:35 AM Thread Starter
well the issue was just the new Sylvania bulb...defective...I put in another bulb and both sides are the same level of illumination...
Bill
'66 GTO head light switch/ tail light problem trialsmm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 01-25-2016 01:22 AM
Light up the darkness: aftermarket head/tail light options Orion88 1964-1974 Tempest, Lemans & GTO General Discussion 7 01-17-2014 10:17 PM
tail panel / tail light bezel ideas 44070dart 1964-1974 Tempest, Lemans & GTO General Discussion 6 05-27-2012 02:59 PM
HELP!!! Please 67 tail light wiring 67wayz 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 04-04-2011 09:12 PM
65 ignition socket t3 bulb socket crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 11-15-2009 05:41 PM
