Trouble starting cold '06 - Pontiac GTO Forum
post #1 of 17 (permalink) Old 11-07-2013, 09:50 AM Thread Starter
I'm not sure if it's because of it getting colder outside, but as of late it's been about a 50/50 shot on whether or not she'll start on the first try. It turns over and sounds like it wants to catch, but then it just dies again, but it lights up just fine the second time. What gives?
AirmanJoker is offline
post #2 of 17 (permalink) Old 11-07-2013, 01:51 PM
battery cables loose? how many miles does it have on it?
mikes06goat is offline
post #3 of 17 (permalink) Old 11-10-2013, 09:03 AM Thread Starter
95k. Tried new spark plugs and a fuel system cleaning, but no dice. What's next on the list to try?
post #4 of 17 (permalink) Old 11-14-2013, 06:04 AM Thread Starter
...actually, I retract my last post, as the cleaner must be working it's magic finally.
...except now I just lost my radiator on the way home from work. Fuuuuuuuuuuuuuuuuuuuu-
post #5 of 17 (permalink) Old 01-15-2014, 01:18 PM Thread Starter
Annnnd to bring this thread back from the dead, the same problem's baaaaaack. Anybody?
post #6 of 17 (permalink) Old 01-22-2014, 04:07 PM
AirmanJoker, have you had any luck fixing this issue?
I just got my 06 GTO 6 Speed and I'm having a similar problem. It only has 76k though. I pretty much have to start it twice to get it to turn over. I let it try to start for a few seconds, then turn the key all the way back and start it again. It usually starts up right away on the second attempt. Some times on the second start, it will almost start but doesn't seem to be getting enough Air or Fuel and dies off after a few seconds.
After reading several other posts on starting issues, I've decided I'm going to first try the easy cheap stuff like fuel cleaner, new air filter, and MAF cleaner. I'll get back with you when I've done that and let you know. It may be a couple of days though.
Eric_SA is offline
post #7 of 17 (permalink) Old 01-23-2014, 12:31 PM
I put in some STP fuel injector cleaner in half tank and drove about 70 miles yesterday. Last night I cleaned my MAF with CRC MAF sensor cleaner. I still haven't purchased a new Air filter yet.
This morning, I went to take the car to a transmission specialist(another annoying issue) and it actually started on the first try. I haven't started it enough times to really say my issue is fixed and I'll post again in a few days.
Eric_SA is offline
post #8 of 17 (permalink) Old 01-25-2014, 03:41 PM
Update, since I used the fuel cleaner and cleaned my MAF, I have been able to start my GTO on the first try for the last couple of days despite the freezing temperatures lately in San Antonio. If you haven't done so already, I would suggest spraying off your MAF with CRC. I hope you get your issue fixed, please let me know if you find that something else was causing the starting issue. My fixed starting problem may only be temporary like yours was.
Eric_SA is offline
post #9 of 17 (permalink) Old 01-25-2014, 10:38 PM
What kind of gas do you use? 93 and only 93 works best for me. I let the wife drive my 04 to work and of course she put 87 in it without me knowing. For a few days I had it torn apart because it had issues starting. SMH crap gas.
Deltoid04 is offline
post #10 of 17 (permalink) Old 01-26-2014, 05:06 AM
silversport's Avatar
87 octane shouldn't cause any starting issues...just retard the timing a bit...but bad gasoline is bad gasoline...if using a cleaner...try something with Techron (Chevron product) it is the better cleaner...
Bill
**QSM/RH/A4/17**1 of 52**
silversport is offline
Difficulty starting 69 Goat when cold droptop69goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 05-08-2013 03:32 PM
Am I in trouble? vette68 Service, Maintenance and Technical Discussion 7 06-10-2006 01:52 PM
hard cold starting my1971gto4spd 1964-1974 Tempest, Lemans & GTO General Discussion 3 04-10-2006 07:19 PM
Cold Engine + Cold Tires = Runs like crap! Russ2005 Service, Maintenance and Technical Discussion 14 12-31-2005 12:54 PM
Trouble with my 05 BigDog Service, Maintenance and Technical Discussion 9 04-26-2005 03:44 PM
