trunk will not open - Pontiac GTO Forum
post #1 of 13 (permalink) Old 02-08-2011, 12:47 PM Thread Starter
trunk will not open
Hello,
The trunk on my 06 GTO will not open using the key pad. I can hear the mechanism operating at the truck lid when the button is pushed, but it doesn't open (trunk will open with manual operator). Before I open the lid looking for the problem, does anyone have any suggestions about this? Thanks!
06spiceredterps is offline
post #2 of 13 (permalink) Old 02-08-2011, 01:26 PM
68OldGoat's Avatar
Using the key fob to open the trunk is a little tricky. I found that if you can hear the trunk releasing with the fob, you have about 1 second to open the trunk or it will re-lock itself immediately. Try opening the trunk almost at the same time you are hitting the fob button.
68OldGoat is offline
post #3 of 13 (permalink) Old 02-08-2011, 01:27 PM
jpalamar's Avatar
Mine stays open once I push the button.
jpalamar is offline
post #4 of 13 (permalink) Old 02-08-2011, 01:33 PM
68OldGoat's Avatar
Does the trunk pop open like it is spring loaded, because mine doesn't pop up. Maybe that is why it re-locks itself. Is the trunk supposed to be spring loaded?
post #5 of 13 (permalink) Old 02-08-2011, 01:38 PM
dustyminpin's Avatar
Your automatic latch on the inside of the trunk is broke. It is a very common problem. It happened to me. You gotta take the felt liner off the top of the trunk lid (popping the black plastic rivets out). Then take a big phillips screwdriver and take the latch off. Once that's off, you can hit the key fob and watch the cable move and see where it's broke. There are two separte cables that go to the same latch. One is the manual cable, the other is the remote keyfob cable. That is why your manual latch under the passenger side headrest works but your keyfob won't.
My first go round, I took a heavy duty coat hanger, bent it into a small S shape, and used a puddy that I bought from O'Reily's that has the same effect as JB weld that you have to roll together in your fingers to activate, and once it gets warm to the touch, you apply it where you want it. I took the end of the cable where the factory latch had broke off and stuck it to the coat hanger hook I had made. It worked for about a year then the puddy broke.
My second go round I went to Wal-Mart and bought one of those cheap "make your own fishing leader kits" from the sporting goods section and took the leader wire and made a little hoop and ran it through the factory latch. It works and probably will never break, but the way I've got the fishing leader rigged up in there is rubbing up or pulling against the wiring in the trunk for the trunk light and unless you lift the trunk as you press the keyfob, the light doesn't come on or flickers on and off.
Once the trunk is open I can hit the release button another time or 2 and the light comes on. It's not that big of a deal to me, since I lift the trunk the same time I hit the button anyways, for the same reasons the guys above stated. If I had more free time and more ambition, I'd get back inside the trunk and find out what is rubbing or pulling on the light wires and fix the problem.
dustyminpin is offline
post #6 of 13 (permalink) Old 02-08-2011, 02:27 PM
jpalamar's Avatar
It doesn't pop up, but it does sit just above the lock.
jpalamar is offline
post #7 of 13 (permalink) Old 02-09-2011, 10:58 AM Thread Starter
I think you are on target with the path forward to fix my problem - many thanks!
post #8 of 13 (permalink) Old 02-09-2011, 03:08 PM
Check the adjustment knobs. They are those big black plastic looking screws one on each side of the underside of the trunk. If they are not adjusted properly you can hear the mechanism releasing but the trunk's not unlatching, the trunk does not pop it just releases. Thats your issue.
post #9 of 13 (permalink) Old 02-09-2011, 08:49 PM
My trunk "unlatches". No noticed movement, but you can open it. It also stays unlatched until I hit the door lock button. Or drive the car.
Poncho Dan is offline
post #10 of 13 (permalink) Old 01-31-2012, 07:50 AM
BobS's Avatar
+1 on the adjustment knobs.... I never would have guessed this.
My trunk release was actuating (via keyfob, or glovebox switch), but unless I was right there to lift the trunk, it would not unlatch.
Half a turn (outward) on the rubber stops fixed it. Now the trunk unlatches every time, and pops up ~3/16" when I hit the button.
BobS is offline
Open the trunk simmons68 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 05-29-2010 08:17 PM
Gravana? still open anybody around?? HELP!! cpr 2004-2006 GTO General Discussion 1 04-30-2010 02:39 PM
Hood won't open! MikeTheDiabetic Service, Maintenance and Technical Discussion 5 03-30-2010 02:26 PM
Can't open driver door Choate51 Service, Maintenance and Technical Discussion 3 09-27-2009 08:03 PM
Open headers? JTYLER1604 Service, Maintenance and Technical Discussion 2 06-06-2005 08:00 PM
