Turn Signal Fuse keeps blowing after radar detector install - Pontiac GTO Forum
post #1 of 14 (permalink) Old 01-23-2006, 12:26 PM Thread Starter
My turn signal fuse keeps blowing after installing my radar detector. I crimped a fuse sliver to the hardwire kit for my V1 and now my turn signal fuse keeps blowing. Any idea why? Should I try moving my V1 to a different spare slot? I have it on the column where the turn signals are, should I maybe move it over? Any other ideas?
I've removed the V1 and still am having problems, probably gone through a dozen fuses. It'll work until I throw the car into reverse, then it blows.
Any ideas? Don't really want to take a 1 week old car to the dealer
Also, anyone have any other ideas how to wire it?
HotRodGuy is offline
post #2 of 14 (permalink) Old 01-23-2006, 12:28 PM
johnebgoode's Avatar
Retrace all your steps to make sure you havent got anything else hooked into the signal circuit. Sounds a little strange especially since you disconnected everything.
johnebgoode is offline
post #3 of 14 (permalink) Old 01-23-2006, 12:31 PM Thread Starter
Originally Posted by johnebgoode
You must have the V1 tapped into the signal lamp circuit. Find one that goes hot with ignition only that is strong enough to support the extra load.. Use a test light to find a reliable source.
well, the V1 is removed and i'm still having the problem.
I'm an electrical noob, I put it in the spare slot on the column w/ the signals. I'll move it over later, but for now I have it completely out and am still having the same problem.
Any idea which slot would be good for when I put it back in? Would I be best off buying one of these? (I had it in the spare in the middle column where the 15A at the top controls the signals and reverse lamp)
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
post #4 of 14 (permalink) Old 01-23-2006, 12:38 PM
Take a close look at where you had ait tapped in originally. Maybe something else is touching somewhere that is causing a short. If you pulled everything out and you're still having problem, there is something somewhere you didnt disconnect.
post #5 of 14 (permalink) Old 01-23-2006, 12:39 PM Thread Starter
thanks I'll check everything again, although i've gone over it 2x's now, maybe a little piece of metal got stuck in there or something.
but then again, maybe they've been out since I got the car and just never realized it.
post #6 of 14 (permalink) Old 01-23-2006, 12:55 PM Thread Starter
Made an appt w/ the dealer
Should I tell them about installing the V1 or keep it quiet?
post #7 of 14 (permalink) Old 01-23-2006, 01:28 PM
SSShhhhhhhh.....
post #8 of 14 (permalink) Old 01-23-2006, 01:36 PM Thread Starter
figured
post #9 of 14 (permalink) Old 01-23-2006, 03:17 PM
This is where I wired my cobra 8500, the red wire connects to a switched and non-fused 12 volt source. You will have to use the inline fuse that comes with the V1.
Good luck,
05GTO is online now
post #10 of 14 (permalink) Old 01-23-2006, 03:51 PM
SSShhhhhhhh.....
I heard that!!!!! HAHAHA!!!!
dealernut is offline
