Upgrade brake question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-08-2004, 04:58 PM Thread Starter
Ok, after a little reading on this board and LS1GTO.com I think it is reasonable to say that C5 brake pads will fit on an '04 GTO.
Does anyone have a problem with this statement?
If this is true, then can I also say that I can use C5 rotors? I mean afterall, if the C5 pad will fit our calipers and our standard rotors, is there any reason to believe that a C5 rotor will not fit?
My reason
GMPARTSDIRECT.com has the following
Ceramic C5 brake pad kit for $40.36 per axel, part # 88909667
Drilled and slotted rotor $40.36 each, part # 88926732
To me this sounds like a hell of a package if we can make it work! And for cheep too.
Ceramic pad all the way around, drilled and slotted rotor all the way around and an extra $20 for th break paint kit and bang we have a breaking set up that looks just as good as ours does and stops better than an '05.
I know, I know, if it sounds too good to be true then it is, right? So someone smart tell me what I am missing.
thanks
hm3to1stlt is offline
post #2 of 3 (permalink) Old 12-08-2004, 07:18 PM
Xman's Avatar
check the rotor diameter. The ones you list should be larger than the 11.7 diameter GTO stock. That means you would have to obtain different suspension to caliber bracket. I used the C5 pads on stock rotors and have had no problems. They were new so I did not have to turn them to accept the increased verticle contact area.
Xman is offline
post #3 of 3 (permalink) Old 12-09-2004, 01:02 PM
C5 rotors have a different diameter, a different bolt pattern, a different offset and a different thickness.
1COOLPC is offline
