Vararam Power Wedge throttle angle? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-27-2017, 11:26 AM Thread Starter
Greetings Goat Herders!
I came across a product called a Power Wedge that is suppose to help open up and distribute air to the intake at WOT.
Says it changes the angle of the throttle to open up a lower pathway to nearly 100% claiming to gain an extra 10% airflow on a LS2 or 3
Has anyone installed or had any experience with this product?
cynicslullaby is offline
post #2 of 3 (permalink) Old 12-27-2017, 02:21 PM
GTO44's Avatar
Quoted: 37 Post(s)
Honestly i think they are bogus for ls motors.
But...... i did buy one LoL. I got it used for $20. The guy i bought it from said it made 6hp thru the whole rpm range. For the $20 i was like screw it lets see if this thing works.
Havent installed it yet. When i get my tune im gonna have the tuner get the car dialed in on the dyno. Then add this power wedge and see if it makes any more power...
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
post #3 of 3 (permalink) Old 12-28-2017, 12:38 PM Thread Starter
Am interested in seeing if it does help. I kind of thought it might be a bit bogus but it almost makes sense if there is a restriction on the bottom of the throttle plate that this frees up. I have so much to do to mine before its ready for a dyno and with a car payment makes it harder to save to put more into it but am definitely doing my research to make every penny count. Thanks very much for your feedback.
Pinion Angle - Am I Doing This Right? TonysGoat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 05-12-2019 12:31 PM
'65 Tri Power, throttle cable too long? CP-Mike 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 07-10-2014 10:43 PM
Vararam Power Wedge Roeville Intake and Exhaust Discussions 5 10-24-2012 11:56 PM
Power Aid Throttle body spacer/ AEM intake questions? NJG8GT Intake and Exhaust Discussions 7 11-21-2007 09:29 PM
Vararam Throttle Body Spacer Ace 14 Engine Discussions 2 09-02-2007 08:10 PM
