Very Rough Idle and Stalling With Any Elec Draw - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-02-2013, 12:02 PM Thread Starter
I'm (just) experiencing this same exact problem immediately following the replacement of the gaskets in the K&N CAI. So, how the CAI relates to the engine stalling because of an electrical draw might make zero sense but it sure is the same problem I'm having right now... Will check for air leaks tonight and will also clean the MAF sensor...
321goat is offline
post #2 of 6 (permalink) Old 04-02-2013, 12:50 PM
68greengoat's Avatar
321goat, I moved your post to a new thread rather than resurrecting an old one....
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 6 (permalink) Old 04-02-2013, 01:51 PM Thread Starter
Ah, thanks... and apologies for that; I didn't mean to bring back a 'thread from the dead' but felt some of the information was still relevant.
321goat is offline
post #4 of 6 (permalink) Old 04-03-2013, 01:22 PM Thread Starter
Just to report back (I know i'm pretty much talking to myself here but that's okay) in case anyone has this problem as well here is what fixed it for me: Removed the K&N CAI and throttle body, the MAF also came out as part of the CAI removal. Picked up some MAF Cleaner from the boys down at Pep and gave the MAF a solid cleaning, then gave the throttle body a good shot of carb cleaner. Put the car back together and gave it a test-run at which the car shook violently... really violently, immediately threw the check engine light so I shut her down. I then realized a MAF soaked in cleaning fluid won't sense air flow too well... Let the car sit (to dry) overnight, started her in the morning and she puuuuurrrrrrs. Cleared the code and it never came back.
Another quick point: I had noticed my car had been very thirsty lately and on my drive home last night I monitored the mileage gauge (as accurate as it is or isn't ) and I was getting terrible, terrible mileage - Cruise set at 65 I was lucky to maintain 18-19mpg. This morning on the way in, Cruise set at 70 and I was maintaining a steady 27-28mpg (car is an m6).
Sorry to ramble, thought it might help someone someday... maybe.
321goat is offline
post #5 of 6 (permalink) Old 04-03-2013, 05:23 PM
Thanks for reporting back!
post #6 of 6 (permalink) Old 04-03-2013, 06:16 PM
Not uncommon. I went through dozens of K&N filters and quite a few would come through with little puddles of oil in their wrapping. I used to open the package and lay them on bath towels in the sun to wick the excess oil out. If you ever oil it yourself that's what I'd advise to do.
Very Rough Idle and Stalling With Any Elec Draw freeze916 Service, Maintenance and Technical Discussion 13 05-12-2010 10:00 PM
rough idle CincyGoat Service, Maintenance and Technical Discussion 9 01-22-2009 12:34 PM
Rough Idle JohnC Service, Maintenance and Technical Discussion 11 02-10-2008 09:14 AM
rough idle EDawg Service, Maintenance and Technical Discussion 4 02-18-2007 03:55 PM
Rough idle???? kanibal Service, Maintenance and Technical Discussion 14 08-18-2006 07:09 PM
