walking/throwing belts! whats going on? - Pontiac GTO Forum
post #1 of 19 (permalink) Old 04-27-2010, 02:11 AM Thread Starter
hey guys, i've been beating myself up trying to find the problem, or cure for the belt issue i've been having.
first of all, it an 05 GTO, with a few mods on the pulley system. I have an underdrive crank, and i'm looking for an overdrive alt. when i get on it a bit, i have to pop my hood just to make sure it's still on streight; it likes to walk over a groove or 2 on the tensioner pulley. this in turn pulls it slightly off the water pump pully, and gets it out of line on the power steering a groove or 2.
with this beeing said, i have bought a new tensioner, and a new belt (el cheap-o till i get this fixed). *edit* there are 3 indicators on the tensioner, i'm lined up at the tightest one.*edit* i have considered getting a tensioner pulley machined with higher edges on it, as to "guide" the belt a little better, but i think this might just mask some other problem.
also i have checked the water pump (nice and solid), the power steering has no side to side motion. alt is good, almost looks new, free spins nice and easy. the idler is slightly loose, but i can't see that cuasing anything since it don't jump or walk off the crank UD pulley.
what do you think?
motoristx is offline
post #2 of 19 (permalink) Old 04-27-2010, 02:55 AM
87GN06GTO07IRL's Avatar
If your belt walks your pulleys are not aligned. I take it this started once you installed the ud? I'd start there.
87GN06GTO07IRL is offline
post #3 of 19 (permalink) Old 04-27-2010, 04:02 AM Thread Starter
hate to say it, but I just bought it like this. it only does it when I'm getting heavy into the throttle, and it's only "every-once-in-a-while". i have eye balled it, and it looks good, but then i'm half blind... it hasn't "pollished" one side of the belt either, so i'm thinking it is just getting to where the spring is not taking up the slack or something. this is why i'm going with the idea that if i got a pulley with higher "guides" it might solve it. or just going with a manual tensioner, but I don't want to that route yet.
post #4 of 19 (permalink) Old 04-27-2010, 07:53 AM
GM4life's Avatar
Your crank pulley may not be fully seated. The crank bolt suppose to be tighted to 240ft-lbs. I would try to see if it has the correct torque on it before anything else. Surpintiene belts are not like the old V-belts where they can be slightly off, and still work fine. Some brands of UD pullies have short retention walls, I think one company claims they have tall ones.
GM4life is offline
post #5 of 19 (permalink) Old 04-27-2010, 08:33 AM
jetstang's Avatar
My Vette was eating AC belts, the idler pulleys were shot.
I had a plymouth voyager that was throwing belts, I turned the belt around and it stayed on forever, as if the belt is directional, but it worked.
jetstang is offline
post #6 of 19 (permalink) Old 04-27-2010, 08:35 AM
The bearings should be tight in the idler pulley, if it moves around replace the bearing or the whole pulley.
post #7 of 19 (permalink) Old 05-16-2010, 07:28 AM Thread Starter
ok i resolved my problem.
i retained my stock belt tensioner, put a custom Tensioner pulley on it with bigger/taller edges, it cost 40 bucks on ebay. Bam! no more throwing belts! i'll see about posting a pic of it sooner or later.
post #8 of 19 (permalink) Old 05-16-2010, 07:34 AM Thread Starter
post #9 of 19 (permalink) Old 06-11-2010, 02:15 PM
dquack's Avatar
Send a message via Yahoo to dquack
I was driving heavy down the autobahn today and noticed a slight whining when I hit the off ramp. I pulled it home slowly and noticed the belt had jumped one rib to the outside. I have had the car for 6,000 miles and this has never happened. The outside outer edge of the belt has a slight raise to it now. I think it is going to walk again. I am thinking of replacing the belt any other ideas while I have the belt off?
2006 Black on black M6 - Cam, Supermaxx header system, valvetrain kit, L76 intake, L92 Heads, Volant cool air intake.
http://www.youtube.com/watch?v=-BgmGcv90RM
dquack is offline
post #10 of 19 (permalink) Old 06-14-2010, 02:57 AM
vxssls1's Avatar
Send a message via MSN to vxssls1
ive used the gates high walled pulley ..it worked treat
Gates 38009 Auto Part | Car Replacement Part
222/224 112
241 ported heads 11:1
comp 918's
OTR
25% UDP
ported TB
4 into 1's 1 5/8,3"cats,twin 3" X force
M6,ripshifter
[email protected],390rwhp
vxssls1 is offline
Walking the body off MaL 1964-1974 Tempest, Lemans & GTO General Discussion 11 12-02-2009 08:01 PM
HELP!!! Engine is throwing a fit!! WanaGTO Engine Discussions 3 05-27-2009 01:34 PM
Seat Belts (rear) 66 rick3452 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 06-24-2008 07:21 AM
1967 Seat Belts 77vettejeff 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 01-20-2008 01:43 PM
