Water Pump or T-Stat?? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-08-2015, 11:09 PM Thread Starter
pocketmaster's Avatar
I recently replaced both serpentine belts on my 05 M6. Prior to replacing is had a hell of a squeel. So two days later I noticed the temp on my guage climb a couple notches on the guage and instantly drop back down to normal operating temp (I'm assuming the t-stat was stuck or the fan kicked in). This happened again yesterday, after following a hard freeze over night (15 Deg). The vehicle had been running for a good 30 min on the freeway prior to the temp starting to climb. No coolant leaking. No more squeeling since I changed the belts. I'm thinking T-Stat is sticking, however that T-Stat was replaced last year so its not very old. Guess it could be defective....thoughts??
God Bless Billiards!!!!
pocketmaster is offline
post #2 of 2 (permalink) Old 01-09-2015, 07:53 AM
SANDU002's Avatar
If the water pump is leaking who will see antifreeze underneath the car and around the pump itself.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
64 water pump djones3158 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 12-12-2014 12:52 PM
68 water pump JeffW 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 12-16-2013 12:02 AM
'69 water pump Q etewald 1964-1974 Tempest, Lemans & GTO General Discussion 2 06-15-2012 12:56 PM
water pump Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 03-06-2011 12:27 AM
water pump Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-22-2010 01:02 PM
