What may be causing a 5mpg drop? - Pontiac GTO Forum
post #1 of 11 (permalink) Old 05-13-2010, 10:30 AM Thread Starter
At idle my Throttle Position Sensor (TPS) it's at 16%.
During a freeway cruise it will read 27% - 35%.
Are these within specs?
I'm asking since my GTO is averaging 15MPG since my rebuild.
That is down from 20MPGs that I was getting before.
There are a few things that was changed that may have reduced the fuel economy:
- lower 10.5:1 compression ratio
- upgraded to Ferrea beehive springs (higher spring rates than stock?)
- swapping out the Maggie 112 stock 2.8 pulley for a 2.6 pulley.
Tuning my GTO for the new mods didn't make a difference in MPGs.
My Youtube Channel
Supercharged (Roots) 6.0 GTO
Supercharged (Twin Screw) 3.0 NSX
Supercharged (Centrifugal) 4.3 S-10
batmans is offline
post #2 of 11 (permalink) Old 05-13-2010, 01:36 PM
GM4life's Avatar
Well your compression could have an effect on MPG's and if the engine is still tight then that can have an effect too. The supercharger is pretty much unloading when crusing. Also the time of year and the change in fuel blends could have an effect too. My MPG vary all over the place and I don't really change my driving habbits. Most of it has to do with the season and fuel blends. I go fro 14-17.5 MPG city like driving. I don't do much highway but its usally around 23-26mpg if I do.
GM4life is offline
post #3 of 11 (permalink) Old 05-13-2010, 01:59 PM
jpalamar's Avatar
My fuel economy is about the same all year. 18-19.5 with mixed driving, probally 60-70% highway. I do think it goes down a little in the summer, not because of the fuel, but because I drive it more agressive since the roads are nice and clean.
04 GTO - sold
jpalamar is offline
post #4 of 11 (permalink) Old 05-13-2010, 02:51 PM Thread Starter
I've got 3k miles on the engine so far using dyno oil for break-in.
Nothing has changed for the better. Maybe 1MPG improvement. My highway used to average 28MPGs at 2k RPMs in 6th gear. And city was 15mpg. Now everything has dropped where my average is like my city driving.
My Youtube Channel
batmans is offline
post #5 of 11 (permalink) Old 05-13-2010, 07:13 PM
GM4life's Avatar
You have to realize that you went from an unknown tune that was possably really lean to begain with to a different setup with possably a better tune.
GM4life is offline
post #6 of 11 (permalink) Old 05-14-2010, 12:02 AM
87GN06GTO07IRL's Avatar
Going from a 2.8 to a 2.6 will lower your mileage for sure.
87GN06GTO07IRL is offline
post #7 of 11 (permalink) Old 05-14-2010, 10:45 AM Thread Starter
Even during cruising with no boost? Just wondering what the averages are out there.
I understand that more boost will consume more fuel.
My Youtube Channel
batmans is offline
post #8 of 11 (permalink) Old 05-14-2010, 04:09 PM
Swap it back and see what you get. It's not that hard to change, is it?
post #9 of 11 (permalink) Old 05-14-2010, 04:20 PM Thread Starter
I may do just that.
First I need to have him check my TPS since the readings are higher than normal.
Dunno how much that effects MPGs.
My Youtube Channel
batmans is offline
post #10 of 11 (permalink) Old 05-17-2010, 11:22 AM
TPS readings are totally normal. You will also notice that at WOT, TPS reads 88%. Explanation here HP Tuners Bulletin Board - View Single Post - 2005 A4 GTO Help please.
As for your mileage, your tune might be a little on the rich side. Without being able to look at a wideband, who knows? What do you know about your tune?
Poncho Dan is offline
oil pressure drop Red Doggy 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 02-28-2009 01:05 PM
RE: 04, 05, 06 OEM Drop In's PDQ GTO Intake and Exhaust Discussions 1 06-04-2008 10:36 PM
Drop in Subs The_Bleek Interior Discussions 2 06-01-2007 10:24 AM
CAI Causing Check Engine Light.....? BlownGTO Service, Maintenance and Technical Discussion 16 03-07-2006 12:49 PM
GM About To Drop Off The Edge Wing_Nut 2004-2006 GTO General Discussion 29 05-12-2005 10:18 AM
