Wheel Hop Advice - Pontiac GTO Forum
post #1 of 22 (permalink) Old 01-11-2006, 01:56 PM Thread Starter
Wheel Hop Advice
With the stock tires for the 2005 GTO I never had a wheel hop. Spun like hell then took off. When I purchsed the Nitto Drag radials 275 40 17 for the back I get it quite a bit. I have a hell of a lot better traction with the new tires but it seems to go from a little spin right to grip and wheel hop. Maybe I just need to adjust my driving habits with the new tires. Maybe these tires were meant to be really heated up before jumping on them.
From I understand the hopping is really bad for the back end. If I can't get rid of the wheel hopping should I look to reinforce the backend? If so what are my options.
Thx
Mike Kortney is offline
post #2 of 22 (permalink) Old 01-11-2006, 02:15 PM
Just take some time to learn where the traction point is on the throttle. It can be very difficult with our boys. But it can be done.
dealernut is offline
post #3 of 22 (permalink) Old 01-11-2006, 04:16 PM
Changing out your rear end Diff Cover for the Harrop Diff Cover will make a big difference. You will be eliminating almost all the Differential torque under acceleration and cornering allowing less rear wheel travel.
Braman'sGTO is offline
post #4 of 22 (permalink) Old 01-11-2006, 07:32 PM
LYNMUP's Avatar
How does this effect the wheel travel if it's a diff cover? Do you have a site or a pic? I would like to elemitate the wheel hop issues as well.
'05 QSM M6
LYNMUP is offline
post #5 of 22 (permalink) Old 01-11-2006, 09:07 PM
t0ny's Avatar
t0ny is offline
post #6 of 22 (permalink) Old 01-11-2006, 09:17 PM
johnebgoode's Avatar
Energy Suspension's Rear Sub frame bushings for street use will eliminate a great deal of wheel hop.........open link and scroll down.http://www.energysuspension.com/pages/newpd1.html
johnebgoode is offline
post #7 of 22 (permalink) Old 01-12-2006, 11:14 PM
A lot have found decent success with Koni adjustables. A lot easier of an install.
Im going the cheap easy way first.........Konis and air bags.
'06 Torrid Red M6
Cam
Headers
C.A.I.
Shifter
JHP Pod
Pulley
Pedders stuff
Shizon tuned
Route 66 is offline
post #8 of 22 (permalink) Old 01-12-2006, 11:22 PM
LYNMUP's Avatar
Originally Posted by t0ny
I can definatly see how this would help from these pics. The price seems kinda high. Anyone done this? Is it definatly worth it or better using the money elsewhere?
'05 QSM M6
LYNMUP is offline
post #9 of 22 (permalink) Old 01-13-2006, 07:54 AM
Are you still able to mount the speed sensors with the Harrop diff cover?
ModBoss2 is offline
post #10 of 22 (permalink) Old 01-19-2006, 08:30 PM
LYNMUP's Avatar
Heres a link with a pic showing wher they are mounted.
'05 QSM M6
LYNMUP is offline
