Where is this supposed to plug into? - Pontiac GTO Forum
post #1 of 10 (permalink) Old 03-01-2011, 11:39 AM Thread Starter
I noticed this plug hanging from the passenger side of my front bumper the other day and thought it was just the fog light plug in...wrong. The fog light still works and there is nothing that is seemingly wrong with the car.
I'm sure you guys know where this is supposed to plug into so I figured I wold ask. After a quick look I could not see where it is supposed to go.
And yes I scratched the he** out of my bumper putting it up on the ramps....just wish I would have gotten lower profile ramps BEFORE that happened.
Any info can be helpful...Thanks
2004 GTO - Red
TicketMeRedGTO is offline
post #2 of 10 (permalink) Old 03-01-2011, 12:19 PM
68OldGoat's Avatar
Looks like the plug is part of the original wiring harness. Have you checked to see if it is powered with just the ignition on, then test with just the parking lights on and then with the front lights. Note when the plug is powered and this will limit what this plug goes to. The only things I am aware of near that location that would need power would be the side light, front light cluster, fog light, and possibly windshield washer pump.
68OldGoat is offline
post #3 of 10 (permalink) Old 03-01-2011, 12:28 PM Thread Starter
If it is part of the original harness then it would need a place to go right? I will have to check when it does have power but I know that the side light, fog light, and front light cluster all have their plugs in tact and working.
There is also a limited range that it can travel so it would have to be relatively close.
2004 GTO - Red
post #4 of 10 (permalink) Old 03-01-2011, 07:46 PM
GM4life's Avatar
Does the windshield washer work? Its on that side too. Also what is on that side is the resistor for the DRL's.
GM4life is offline
post #5 of 10 (permalink) Old 03-01-2011, 08:06 PM
Looks like the Washer Fluid Plug
LS2 MN6 is offline
post #6 of 10 (permalink) Old 03-01-2011, 08:24 PM Thread Starter
Yes the windshield washer pump does work.
Could you explain to me what the DRL's are and where the resistors are located?
Sorry for all of the questions but I am a noob to my GTO. Only had it since january.
But thanks for all of the info
2004 GTO - Red
post #7 of 10 (permalink) Old 03-01-2011, 08:50 PM
GM4life's Avatar
Check you horn, its next to the fog light. That were mine seems to go.
GM4life is offline
post #8 of 10 (permalink) Old 03-01-2011, 08:54 PM
Looks like an A/C clutch pigtail. Get out your multimeter and test it.
Poncho Dan is offline
post #9 of 10 (permalink) Old 03-01-2011, 09:25 PM Thread Starter
If this was the case, would the AC work while it was unplugged?
2004 GTO - Red
post #10 of 10 (permalink) Old 03-01-2011, 09:37 PM
GM4life's Avatar
Like I said check your horn. Mine goes to the horn. The AC is on an engine harness not a body harness. What is the color of the wires?
GM4life is offline
Is a 69 GTO supposed to have these? IGOTGOAT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-04-2010 12:19 PM
thats not supposed to be there...... rextheracer 2004-2006 GTO General Discussion 1 06-06-2009 11:16 PM
Date coded plug wires and plug question 70gto 1964-1974 Tempest, Lemans & GTO General Discussion 7 09-26-2008 03:25 PM
It is not supposed to rain in Phoenix. foxtrot7 2004-2006 GTO General Discussion 3 04-26-2007 09:52 PM
What color are the pontiac emblems supposed to be? Aceofaces Exterior Discussions 11 12-20-2006 09:56 PM
