Whining Noise - Pontiac GTO Forum
post #1 of 31 (permalink) Old 05-12-2010, 05:13 PM Thread Starter
Falco21's Avatar
Whining Noise
I noticed that when im accelerating usually from 1st to 3rd gear the car makes a whining noise. It stops when i release the gas pedal and it does not do it when im in 5th or 6th gear or idling. I have a k&n cai and im thinking it could possibly be that, but i never heard this noise before...any suggestions on what it could be?
Falco21 is offline
post #2 of 31 (permalink) Old 05-12-2010, 09:53 PM
Bluegoat05's Avatar
when you say you've never heard it before you mean your car used to not make that sound or that you havent heard it on any car? also does it make the sound if you are parked and rev the engine? your car may have a throttle body spacer on it and they will make it almost sound as if it has a turbo.. if you do have one i would recomend takin it of because they suck i got one for my car and it decreased low end power!!
straight piped cat back, JBA shortys, JBA wires, AEM ca, and 421 slp tune
Bluegoat05 is offline
post #3 of 31 (permalink) Old 05-13-2010, 05:10 AM
B-ville Goat's Avatar
Could also be transmission or rear end whine. Some is normal, especially the trans. If it is faint it is probably normal.
Vice President
Susquehanna Valley GTOs
B-ville Goat is offline
post #4 of 31 (permalink) Old 05-13-2010, 01:10 PM
Bluegoat05's Avatar
ya it could be the tranny but i dont think it would be the rear end because you would still hear it in sixth gear too because mine whines and sixth is when i hear it most
post #5 of 31 (permalink) Old 05-14-2010, 07:45 PM
KyleGT05usmc's Avatar
I have K&N intake and there's a definite whistle under certain rpm/loads. Almost sounds like a 'turbo'-y whine.
I love that sound btw.
K&N CAI, lightly ported stock TB/INT, JBA Hpipe, Spintech Side Exh. ([email protected] r/t .8800 60' 2.06)
1/13/10- Kooks 1 3/4, LS7 Clutch, B&M shifter
1/21/11 - Eibach Springs, Monroe Shocks, EBC Brakes
Soon - "Sungold" PowderCoated 17"s
KyleGT05usmc is offline
post #6 of 31 (permalink) Old 05-14-2010, 08:37 PM Thread Starter
Falco21's Avatar
yea dont get me wrong it sounds sweet. lol but it just made me a little nervous at first lol
Falco21 is offline
post #7 of 31 (permalink) Old 05-15-2010, 12:18 AM
87GN06GTO07IRL's Avatar
Originally Posted by Bluegoat05 View Post
your car may have a throttle body spacer on it. if you do have one i would recomend takin it of because they suck i got one for my car and it decreased low end power!!
Was this according to the butt dyno or a real dyno?
87GN06GTO07IRL is offline
post #8 of 31 (permalink) Old 05-15-2010, 05:43 AM
You're describing rear end whine.... Car out of warranty? Still take it to the dealer and have them look at it they may be able to help you out. They can, question is will they? This was a major issue over the years. The first step would be to replace the oil and add new F.M. but this won't help but its procedure. The longevity of the rear with the whine was a concern.
The rear end is not a GM part thats why they were replaced and not rebuilt. Dana was responsible for this. Good Luck
post #9 of 31 (permalink) Old 05-15-2010, 09:11 AM Thread Starter
Falco21's Avatar
The only problem with that was that I purchased this car from a private seller....so i dont have a dealer to go back to lol so wat would be the thing to do considering i cant go back to a dealer? Also it seems the whine comes from the front of the car not the rear though? Thanks GTO Judge
Falco21 is offline
post #10 of 31 (permalink) Old 05-15-2010, 09:33 AM
Did you check your power steering fluid?
"Is that a supercharger boy, or is your power steering pump on the fritz?"
Poncho Dan is offline
I hear a whining?? NEED HELP PLEASE.. redls1gto04 Engine Discussions 5 03-21-2009 04:08 PM
Really bad whining/scraping noise when depressing clutch pedal hcpcjj Service, Maintenance and Technical Discussion 4 02-04-2009 12:42 PM
Whining noise?? The_Bleek Engine Discussions 18 06-09-2007 05:53 AM
whining sound?? PhantomGTO Service, Maintenance and Technical Discussion 12 06-29-2005 08:20 AM
Whining from the rear end DavidT Service, Maintenance and Technical Discussion 6 04-14-2005 09:22 AM
