Will 3:91 gears fit in stock diff? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-18-2010, 08:17 AM Thread Starter
Whining/rubbing noise coming from rear end. It's louder when in gear and I let off the gas. I was told I likely need new gears but should replace the different just in case it's not the problem. My question is, if I order 3:91 gears and the install kit, will it fit in the stock pumpkin? I ask this because I heard stories of people buying some and them not fitting. Could it have been that they bought defective or wrong brand? I plan on getting mine from the difftechnics company (I know we're not supposed to mention websites) in Australia.
DeuceDaProdeuca is offline
post #2 of 4 (permalink) Old 05-18-2010, 08:40 AM
GM4life's Avatar
Yes 3.91's are OEM GM gears from what I was told.
I would do further reasearch on the diff. I'm not a diff guy so don't quote me. I thought on decel if it was making noise it had to do with pinion baring? On accel it was the gears.
GTO Performance
GFORCE1320 AXLES STUBS CLUTCHES DSS HENDRIX HALF SHAFTS 8.8
GM4life is offline
post #3 of 4 (permalink) Old 05-18-2010, 11:00 AM Thread Starter
It does it at decelerating, acceleration, and when cruising in gear and cruising in neutral. No, its not tires. Its just much louder when gears are engaged and of the clutch and gas.
post #4 of 4 (permalink) Old 05-18-2010, 11:05 AM Thread Starter
GTO Performance
I do thank you for your response.
where to get 3.91 gears NjDevilCar 2004-2006 GTO General Discussion 0 05-26-2009 07:35 PM
what size stubbs, axles, driveshaft can fit stock diff? banshee 2004-2006 GTO General Discussion 2 07-29-2008 08:01 AM
Gears? JGOAT Service, Maintenance and Technical Discussion 0 10-22-2007 05:00 PM
stock diff parts wanted banshee 2004-2006 GTO General Discussion 0 08-21-2007 09:04 PM
Will the new holden L92 intake fit on stock heads? Ozzhead Intake and Exhaust Discussions 1 01-21-2007 09:47 PM
