Will z06 rims fit - Pontiac GTO Forum
post #1 of 15 (permalink) Old 06-14-2005, 03:34 PM Thread Starter
Will z06 rims fit
I wanted to put the black z06 rims on my black 05 goat.I've heard the lug pattern does'nt match up.Does anyone know if this is true?
wildchildm39 is offline
post #2 of 15 (permalink) Old 06-14-2005, 05:21 PM
6QTS11OZ's Avatar
I don't think so but I'm not sure. If you go to the Tire Rack or Discount Tires website and select the wheels for a Z06 it will show you the bolt pattern for the wheel. Hope this helps!
And if you didn't know the bolt pattern for the goat is 5X120.
~I'm ya huckleberry~
~516rwhp/500rwtq~
6QTS11OZ is offline
post #3 of 15 (permalink) Old 06-14-2005, 05:26 PM
b_a_betterperson's Avatar
I've seen other people try to bolt Corvette wheels on GTOs. Doesn't work. The rear Corvette wheels don't fit at all. The fronts do -- but they stick out of the wheel wells by about an inch. Nice idea, though, just isn't feasible. Kinda wish the 5-spoke WS6 wheels from 2000 fit on the GTO as they look pretty good, too.
b_a_betterperson is offline
post #4 of 15 (permalink) Old 06-14-2005, 05:40 PM Thread Starter
Thanks for your help.I guess I'll start looking at different rims.
post #5 of 15 (permalink) Old 06-14-2005, 05:49 PM
5 spoke WS-6 wheels fit on the back only, tried it and they BARELY fit..... fronts are too damn wide..
GTODEALER is offline
post #6 of 15 (permalink) Old 06-14-2005, 05:54 PM
All of the above mentioned rims are the wrong bolt pattern at 5x120.65 (GTO is 5x120), so offset and width are not the only issues.
djdub is offline
post #7 of 15 (permalink) Old 06-14-2005, 05:57 PM
Originally Posted by djdub
All of the above mentioned rims are the wrong bolt pattern, so offset is not the only issue.
.....true, btw what's up with your avatar??
post #8 of 15 (permalink) Old 06-14-2005, 07:29 PM
Send a message via AIM to ftlfirefighter Send a message via Yahoo to ftlfirefighter
all it needs is a white picket fence!
ftlfirefighter is offline
post #9 of 15 (permalink) Old 06-15-2005, 08:52 AM
The C5 Z06 wheels are awesome. Rears are WAY to wide and fronts are just too wide. I sent an email to OE Concepts that makes Z06 knockoffs. I asked if they had bolt patterns, width and offset that would fit the GTO and to my surprise they said yes. I have yet to actually check it out, but if you have a local distributor you are golden.
bomber76 is offline
post #10 of 15 (permalink) Old 06-15-2005, 01:27 PM Thread Starter
Thanks for the help bomber.I will look in to that.
