Max Power - Pontiac GTO Forum
post #1 of 7 (permalink) Old 06-02-2011, 12:34 PM Thread Starter
Max Power
Can you tell I need a set of drag radials? Rollout is ok, but you sure can't mash it right away.
Note the zero wheel hop on the stock suspension.
Poncho Dan is offline
post #2 of 7 (permalink) Old 06-03-2011, 09:13 AM
GM4life's Avatar
I used to be able to say I had no wheel hop on stock suspension. Add more real power and wheel hop is there, harder and more expensive to control.
GM4life is offline
post #3 of 7 (permalink) Old 06-03-2011, 10:14 AM Thread Starter
Oh, I'm sure I'll chew the crap out of the stock driveline with 400+. Especially if I hook. I'm actually kind of afraid of putting on aftermarket rear springs with increased spring rate for now with the factory shocks. I'd prefer to do all new bushings along with shocks when I do springs. Need to find some adjustable I can dial in easy when I want/need to. Figure I can crank em up real stiff and it should be a good remedy for say, at the track.
post #4 of 7 (permalink) Old 06-03-2011, 10:55 PM
GM4life's Avatar
I feel ya. Talk to svede sounds like he got a good set up with Lovells springs and Koni shocks and struts. I'm going to experiment with a SLP sway bar soon as it comes in. I read from DMS that it not only helps with cornering it also helps with 60'. I don't drag race but apperantly it helps with the uneven distribution of torque.
GM4life is offline
post #5 of 7 (permalink) Old 06-04-2011, 11:28 AM Thread Starter
That makes sense. Hopefully it helps. I never figured the anti-roll bars were that bad in this car (I am used to driving a Grand Am, after all ) it seems to handle really well for being a big battleship, even with passengers and a trunk full of schtuff. But I never really try to "push the envelope" around corners, either.
post #6 of 7 (permalink) Old 06-05-2011, 01:58 PM
GM4life's Avatar
The sway bars are not that bad. I upgraded all the sway bar bushings and that was good enough. I think they sould be the last thing you replace after everything else sould get them to fine tune the suspension.
GM4life is offline
post #7 of 7 (permalink) Old 06-06-2011, 01:10 AM
87GN06GTO07IRL's Avatar
Get some Powergrid adjustable links to compliment the set up. You wouldn't believe how much preload is on the front bar.
87GN06GTO07IRL is offline
  Pontiac GTO Forum > Off Topic Discussions > Audio & Video Clips
Power Windows, Power Locks, Seat Belts, Power Rear View Mirror, Back Speaker Location GQUINCOCES 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 01-03-2009 07:18 PM
sleeper to the max koman Racing and Kill Forum 5 04-29-2007 10:45 AM
Max HP for an 05 Goat GTO676 2004-2006 GTO General Discussion 2 07-06-2005 04:47 PM
Mad Max fffernan The Lounge 4 01-05-2005 02:46 PM
